Old 02-14-2004, 03:27 PM
MaxAgHammer MaxAgHammer is offline
Question Please Help! Bumper Cover
My headlight covers have fogged over, and I am in the process of removing them to give them a cleaning. The only way I could tell to remove them was to first remove the bumber cover. I have got almost all the bolts/screws out of the bumper cover, but there is one of those plastic screws right underneath the headlight cover.
Does anyone know how to remove the screw beneath the headlight covers? it almost looks like I would have to remove the headlight cover first, which i might be able to do, but I am scared I won't be able to get it back together.
any help would be gratly appreciated.
Old 02-14-2004, 03:28 PM
Re: Please Help! Bumper Cover
sorry i have a 95 eclipse rs
Old 02-14-2004, 03:53 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
You dont need to remove the bumper.... just take an super long socket extension and a socket on the end of it and wrap a rag on the end so it does not scratch anything. Then push it in there, and get it on the end of the bolt and unscrew that sucker out
Dont worry i learned it the hard way too.
For Sale 98 Eclipse GS, 5 spd
Old 02-14-2004, 05:56 PM
Thanks for the reply, ashah000. Sorry for being a little dense, but I just want to make sure I understand. Your talking about pulling out the entire headlight houseing, correct? Not just the clips to the headlight cover. How did you go about getting the socket in there? Through the fog light holes or some other direction.
Thanks again for the information. I've got to get this car back together before the wifey gets upset.
Old 02-14-2004, 06:10 PM
ashah000's Avatar
Yes I am talking about the whole headlight, I put the extension through the gap between the headlight and the bumper.
Old 02-14-2004, 07:10 PM
thats going to be tight. I can only push the bumber cover down enough to get about a 1/4 inch gap directly under the headlight. Thanks again for the advice.
Old 02-14-2004, 07:18 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
yea you just slide a 10mm socket and a long extention i didnt even use a rag and it didnt scratch. i dont kno why they designed the headlights liek that. you cant take the headlights out without takin the bumper cover off and you cant take the bumper cover off without takin the headlights out..... stupid
Old 02-15-2004, 11:39 AM
hey how do you clean those headlights? i dotn want to break them and i cant get the lens off of the housing.
Old 02-15-2004, 11:59 AM
ashah000's Avatar
To get the lens off you have to bake them, so the glue heats up, and then you can take it apart.
Old 02-16-2004, 01:34 AM
kjewer1 kjewer1 is offline
AF - Advisor
I just go in from the backside with a bare hacksaw blade and cut that POS lower mounting tab clean off... Makes it easier for me to pull that headlamp at the track for cold air intake. In my pics on my page you cna see the headlight missing in the track shots. I use just the top most 10mm to hold each headlight in. Just my method, if you get fed up with trying to get that bolt out
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-30-2004, 08:52 AM
oxide7 oxide7 is offline
Send a message via AIM to oxide7
95 GSXracer,
can the same thing be done for the 97-99 model? im having a few problems...
Old 03-30-2004, 03:22 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
there is also another way that is way easier than taking off just the cover, you can take off the whole bumper...
[this is very easy if you jack up the front end from behind the front wheels]
take off the 2 bolts in the wheel wells [both] and pull gently to pop the cover off the body
remove the bolts holding the front clip to the top by the latch.
look under neath and you will see 2 parallel bars facing fore and aft, aparently attatched to the bumper. there are 2 bolts on either of them. remove these 4 bolts.
the whole bumper will now slide off, cover and all.
this worked 10000% better than doing battle with the bumper cover itself. i looked at the fact that the light has to be moved to take off the cover and the cover has to be moved to take off the light and figured there has to be another way. the guy's at Mitsu aren't so smart that they make a sic engine and no easy way to do this...
oh, and on the 2nd page of the link in my signature is a write up on how to split the headlight housing. me and a friend originaly came up with the plan on a 95 gst [now resting in totaled car heaven]
Old 03-30-2004, 03:53 PM
the red circles indicate what to unscrew
Old 03-30-2004, 04:13 PM
Import2nr99's Avatar
Import2nr99 Import2nr99 is offline
Boosted spyder beat me too it. DAMN YOU MAN! and here I thought I was gonna have a chance to look smart. Follow the diagram he included (very nice) and the whole bumper will come off making the headlights very easily accessable. Either cut or bake. Both are pretty easy, one is a little more permanant. After finishing you might want to add some silicone to keep this problem from happening again. that way they're completely sealed and they won't fog over again. then just repeat the process and put the bumper back on. Shouldn't take you more than an hour to do everything. Good luck
V8's are like tampons, every pussy needs one!
Old 03-30-2004, 05:13 PM
funny part is i had no diagram or help and it took me like 4 hours to do what i was doing [taking the amber turn lens out], essentially the same as you are going to do...
