Old 02-14-2004, 03:25 PM
eclipseracer92 eclipseracer92 is offline
speedo not working
I have a 90 accord ex 5spd manual and i cant digure out why the speedometer keeps cutting off. It usually doesn't work at all but some times it does i dunno if its a lose connection or what. But im really having probs not havin this thing work so if you could please help it would be great. Thanx
Old 02-26-2004, 10:40 PM
mwkirchner's Avatar
mwkirchner mwkirchner is offline
Re: speedo not working
It sounds like you may have a bad VSS ... Vehicle Speed Sensor.
To make sure if it is indeed that and not the speedometer ... try this:
Hopefully you have cruise that works on your car. Let's assume that it does. Get going on the highway and get to cruising speed. Now ... set the cruise. If it holds ... then the speedometer is the problem. If it does NOT hold ... then the VSS is the culprit.
Hope this helps.
Mark
Old 02-27-2004, 09:46 AM
dutchaccord dutchaccord is offline
Try THIS link
1 st........2nd........3rd
====== ==== == [[ ] ] H22A
Upcomming: Porche 964 brake swap
In progres: Boostin the H22
Old 02-27-2004, 06:36 PM
badassaccordriver's Avatar
badassaccordriver badassaccordriver is offline
Send a message via AIM to badassaccordriver
got kinda scared when i saw the title of this thread......
