Old 02-14-2004, 11:31 AM
projectsilvia97's Avatar
projectsilvia97 projectsilvia97 is offline
Send a message via AIM to projectsilvia97
'91 Civic LX
Hey guys, i have some questions. they are sort of newbie questions, but i'm a noob to this part of the forum. i am upon purchase of a 1991 civic lx 4 door. i was just wondering, what engine does this car come with? would it make any difference if i swapped in a D15b SOHC VTEC engine? if i were to do this swap, what axles would go this engine, since the does not come with axles. also, could i use my stock ecu on this swap? thanks for the info.
projectsilvia97
Old 02-14-2004, 01:10 PM
Old 02-14-2004, 01:57 PM
GTA's Avatar
GTA GTA is offline
Whee..
Re: '91 Civic LX
it come with a d15b2 non vtec engine with dual point fuel injection. you would have to convert the car to multi point fuel injection for the vtec swap. you would need a new ecu for that too. the axles will work since you need to use your stock tranny, which will bolt up to that engine.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 02-14-2004, 03:04 PM
so if i got the D15b from hmotorsonline, i wouldn't have to buy there tranny because it would bolt up to my tranny? same with the axles right? where would i get this new ecu, from hondata or something? thanks for info GTA
Old 02-14-2004, 09:44 PM
CZ-R's Avatar
CZ-R CZ-R is offline
Send a message via AIM to CZ-R
Ummm...yes. Your tranny & axles will work if you get the SOHC VTEC D15. You should be able to get the ECU from the same place you get the motor. Or you can keep the ECU you already have & hook up an RPM activated switch for the VTEC.
A buddy of mine swapped the VTEC D15 into his CRX & he used the stock ECU with a toggle switch for the VTEC (NOT recommended). A RPM activated switch can be bought from MSD for about $30.
*Edit* My bad, the friend of mine that did the swap was starting with a Si platform. Greg's correct in that you have to convert (the wiring) to MPFI. That should be pretty easy. You could always get an Si wiring harness & ECU off eBay for less than $200 (total for both).
Old 02-14-2004, 11:38 PM
the one on hmotorsonline is just the long block though. do they sell ecu's there? or should i go hondata or somethin?
Old 02-15-2004, 01:05 AM
CZ-R's Avatar
yes, they sell ECU's there. And the 'long block' just means that it doesn't include the tranny - which you don't need anyway.
If I were you I'd just find a CRX (or Civic Si) ECU - I think it's the PM6, but I could be wrong. Then just do the MSD RPM activated switch. It would probably be cheaper than the ECU from Hmotorsonline...
Old 02-15-2004, 07:07 AM
88sedan_civic 88sedan_civic is offline
Send a message via ICQ to 88sedan_civic
you can find ecu's anywhere on the net for civics..you just gotta look harder..ebay, thepartstrader.com, they all got it ..
-meng
90' Toyota Supra Turbo
Mods:SP63 Turbo kit .68A/R Qtrim. HKS GT 60mm wastegate, JE pistons,Crower rods,Ferrea valves,port&polish head,AEM camgears,Webcams camshafts,HKS 1.2 MHG,MKIV TT intake manifold, Hybrid Intercooler, HKS carbon titanium exhaust system, 3'' custom downpipe, RC720cc injectors,HKS EVC IV,PHR ecu,Blitz ssbov,Chevy TH400 3spd tranny,Hurst shifter,Bosch 1000hp fuelpump,Cartech Fuel Pressure Regulator,Unorthodox Racing pulleys,HKS twin ignition system,custom driveshaft, and a K&N
Old 02-15-2004, 11:07 AM
what is the ecu called again? could i find this on hondata?
Old 02-15-2004, 11:53 AM
CZ-R's Avatar
I'm sure you could find a Hondata that would work, but it probably won't be cheap... You could find a CRX/Civic Si ECU for about $50 (maybe even less), and do the RPM activated switch for about $30. Why spend more on just the ECU?
Old 02-15-2004, 11:54 AM
viper_2_4's Avatar
viper_2_4 viper_2_4 is offline
Send a message via MSN to viper_2_4
Re: '91 Civic LX
ya I believe it would work with an activated switch. I believe however, that the JDM D15B VTEC is the one with the 3 stage VTEC, I think you could run it with an RPM switch however, but I don't know if it would work properly (all 3 stages). I am not sure but I would think that you would need the correct ECU to run that (so you couldn't use one from a D16z6 or y8)....I think atleast, never had one.....
Old 02-15-2004, 12:01 PM
what exactly is the RPM activated switch?
Old 02-15-2004, 12:18 PM
do all the '91 civic sedan models come with the same engine?
Old 02-15-2004, 01:29 PM
CZ-R's Avatar
Re: '91 Civic LX
I've never personally used one, but I know people who have & they liked them. Go here for more info.
No, the EX has the D16A6. All the others have the D15B2 or D15B1.
Old 02-15-2004, 11:37 PM
wouldn't it just be easier to buy a vtec controller? what rpm does the vtec kick in at on the D15b
