Old 02-13-2004, 10:23 PM
blade34609's Avatar
blade34609 blade34609 is offline
Negative Battery Terminal Spark?
Hi,
Got my D16A6 engine in my car for the first time.
So i go to connect the negative battery terminal and it just sparks real bad. I dont wanna try to tighten it cause im afraid ill get shocked.
Could I have left something out? I just put a new fuse panel in.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 02-13-2004, 10:32 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Negative Battery Terminal Spark?
does it keep sparking or does it stop??? Cause if it only sparks for like a sec just put it on real quick and itll be fine!
Old 02-13-2004, 10:35 PM
blade34609's Avatar
keeps sparking
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 02-13-2004, 10:41 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
to what? between the battery and wire is okay, you can not get shocked by 12V. The more stuff running (headlights, radio, etc..) the more it will spark as you hook it up.
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 02-13-2004, 10:51 PM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
if you hook it up and its sparkin like crazy....then your polarity is reversed in the battery, or you have a positive wire possibly grounding out.....I'd re check the electrical system.
89 DX: LS Powered
88 CX: Project ZC
Old 02-14-2004, 12:37 AM
blade34609's Avatar
I tried again and connected it to the negative terminal. It sparks real crazy then stopped sparking once it was on there. then it even started to melt the battery termnial. I quickly took it off.
Ill try and recheck the postive wires tommorow morning.
If anyone else knows what might cause this problem please let me know.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 02-14-2004, 01:13 PM
blade34609's Avatar
Alright I double checked the wiring and it looks fine.
I tried puttin the negative terminal on first, then I put the positve terminal on. It stopped sparking and looked like it would work.
But I went to turn the key on and there is absolutely no power.
Could the battery have lost all its power just for sitting for 2-3 weeks?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 02-14-2004, 01:59 PM
sounds like you have a moajor short, vet a voltmeter and start looking.
i wish it was fast
here is my website
Old 02-14-2004, 03:43 PM
blade34609's Avatar
Found the short, thanks guys for your help.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 02-14-2004, 04:37 PM
hitr99 hitr99 is offline
what was it?
98 mustang gt will not start after negative battery terminal went bad bratt Mustang Problem Diagnosis 6 07-24-2009 06:07 PM
Cant Remove Negative Battery Terminal Nut timber284 SC/SL/SW 5 06-15-2008 12:47 AM
negative battery cable mrhapa Mighty Max 0 01-17-2005 11:24 AM
