Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 02-13-2004, 05:23 PM
mcmikey mcmikey is offline
Audio Wiring Diagram Wanted
Could anyone with a service manual please scan in the Audio wiring diagram for a 1998+ Passat.
I need the pin numbers and function names for the CD Changer connector located in the back of the vehicle.
Thanks.
Old 02-19-2004, 12:35 PM
boschmann boschmann is offline
Re: Audio Wiring Diagram Wanted
I can relate wire color to pin # which may help, but not function. Pin 1 = Orange, pin 2 = green, pin 3 = brown (ground), pin 4 = black, pin 5 = not used, pin 6 = violet, pin 7 = white, pin 8 = yellow, pin 9 = blue, pin 10 = red. All hook to the radio unit except the ground. I can also tell you where they hook to the radio if you need. Are you trying to install a factory type player. I've heard that on some models if you install a CD player & can't get it to work you may have to have the radio recoded with a scan tool to recognize that it now should look for the CD player.
2004 Elantra audio wiring diagram Rajan Elantra | Avante 1 02-16-2009 06:24 PM
04 mustang special edition audio wiring diagram khienluong Mustang Talk 1 01-11-2007 03:58 PM
audio wiring diagram acat Older Pickups 1 10-08-2005 08:16 PM
Subject: audio wiring diagram needed!!! forum80 Galant 5 10-05-2003 06:34 PM
Maxima 96 audio wiring diagrams shliah Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 04-13-2001 05:34 PM
