Old 02-13-2004, 03:11 PM
joyrider joyrider is offline
1995 3/4 ton van with u-joint problem (?)
I've got a 95 van with a clunk underneath when shifting gears. I assume this is the u-joint--what's the quick 'n' easy way to check, and is there a way to replace it without tearing out the whole driveshaft???thanks!
Old 02-13-2004, 10:29 PM
comp comp is offline
it can be a trans. mount (pull down real hard on tail shaft it should flex
down, not already be on the crossmember, then see if there is just a
little side to side flex) you may have a "carrier bearing" it's a flex joint
to support a long drive shaft( move up/down/side/side) it shouldn't move
to much . u-joints are checked about the same as the carrier, apply the
pressure with a small pry bar, DO ALL THIS on flat ground with wheels
chocked so there is no load on drive-line work safe, get a shop manual
to understand this better
1993 chevy 3/4 ton van brakes paulyd76 Express | G Van 3 03-29-2014 10:36 AM
3.4 From 2003 Monte Carlo into 94 Firebird? iamdallas Engine and Transmission 0 03-21-2010 08:39 PM
1995 3/4 Ton 454 No Spark bigj-dog C/K 8 10-27-2006 08:52 AM
93 3/4 ton van daninpa Express | G Van 0 06-09-2005 05:57 PM
Need help with a 3/4 ton dodge? Wont start muddlesinpuddles Ram Pickup | Ram SRT10 4 08-24-2004 06:17 PM
