Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 02-13-2004, 01:49 PM
Revelation Revelation is offline
baffled....fuel related
okay car broke down did a fuel pressure test getting no fuel pressure
i replaced the relay still no dice then i dropped the tank and replaced the fuel pump and strainer last night still wont crank up
my car is a 1986 ford thunderbird 3.8L
if anybody can give me some helpful advice or possibly a wiring diagram for the fuel system please respond
thank you
Old 02-18-2004, 10:27 PM
tommie99 tommie99 is offline
Send a message via Yahoo to tommie99
Re: baffled....fuel related
ok on your car there is a fuel cut off switch i think it is in the trunk on the left side i looks like a button make sure it is pushed in if it is unplug it and jump the wires they are bad about shorting out (the switch) the fuel switch is for when you are in a accident i have seen them even trip when you hit a bump in the road let me know if i helped you ...........tommie99
Old 08-13-2005, 05:57 PM
ledso ledso is offline
thank you
He i Got a 1990 supercharger, coul you please teel me where can i find the fuel pump relay?
Old 08-16-2005, 10:29 PM
coondawg6 coondawg6 is offline
if you found the inertia/fuel cutoff switch tested or bypassed it and it still wont work look at you battery and there is a black wire about 12 gauge wire(little diameter) that hooks up to the ground side.. thats your ecm ground and if it comes off everything will work except fuel--i have seen this happen many times due to battery corrosion
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
