Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-13-2004, 10:14 AM
bruce94 bruce94 is offline
Drives side door will not open
Hello All,
My borther has a 1994 buick regal...the lock is stuck he puts the key in but he can't turn it. He has tried to get the panel off inside to get to see if he can fix it but the door needs open in order to do that. Any ideas????
Old 02-13-2004, 10:16 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
is it cold where you live? has it snowed recently? The lock could be frozen.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 02-13-2004, 10:21 AM
ya ..it is about -6 here today!! oh i am in newfoundland, canada! It happened last week..he just came out one morning and he couldn't move the key in the lock at all!! He tried to get the panel off inside but of course the door got to open in order to do that!!
Old 02-13-2004, 01:02 PM
pcv pcv is offline
Hypsi87 is right. Looks like your lock is frozen due to moisture in the lock cylinder. Put some lock de-icer and wiggle the key a few times till it comes loose.We had this problem, here in Ontario, Two weeks ago.
Good Luck.
NOTHING LIKE AN OLD CAR.
Old 07-13-2004, 12:25 AM
mattmort_1983 mattmort_1983 is offline
Re: Drives side door will not open
Hey buddy i figured it out with dumb luck... it seems the solenoid sticks... messed my door up a bit taking it apart... try locking it manually then try the key.... i noticed if i press lock twice sometimes that works and it always works if i lock the drivers side door manually first and then press the power lock button.... try that out it will definately help remember the key will not turn the lock if u can not lock and unlock manually from the inside fiddle around till it does it properly from the inside and then try outside....
