Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-13-2004, 01:06 AM
IntegraB18LS's Avatar
IntegraB18LS IntegraB18LS is offline
Is there any difference in the B18A and B18B blocks?
I think Im going to need a rebuild sometime soon with the amount of beatings i been giving my motor. I am looking for mainly a lower end, B18A's are very common so they are cheaper. I plan to use a block guard and put new pistons and rods in, use stock block and crank then maybe go with a b16 head if i have enough money left. is the B18a block and crank the same as a b18b or what is the differences? I know the b18b has a better flowing head.
Kyle
Also I am plannin to run 10psi steet and 15 on the track, I want the JE pistons, the cheaper eagle rods, and im going to block guard it, should I be safe or will I need better parts?
[url=http://www.automotiveforums.com/vbulletin/showthread.php?
1995 Honda Civic EX
-Integra B18B1 LS engine
-Turbocharged
-Rear disk conversion
-Many mods
Cheak out my civic (cardomain)
Easly got 10k into this car with everything and it still looks like a POS
Old 02-13-2004, 01:40 AM
SenseiAccord SenseiAccord is offline
i heard that the b18a and b18b got different cams. something like the b18b got better ones or some sh*t like that.
Old 02-13-2004, 04:44 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Is there any difference in the B18A and B18B blocks?
As far as the block goes they are almost the same, the B18A1 has weaker rod bolts, but an ARP upgrade will cure that.
Old 02-14-2004, 12:12 AM
alright thats good, the only thing staying stock on the block will be the crank and sleeves so i should be all set to get a B18a and slap on some forged pistons and a vtec head then my turbo cool
1995 Honda Civic EX
-Turbocharged
-Many mods
Old 02-14-2004, 03:09 PM
whtteg's Avatar
Get a girddle and a bseries VTEC oil pump, you will need them.
