Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-12-2004, 09:37 PM
B1SiR6A's Avatar
B1SiR6A B1SiR6A is offline
Fourth Mod ?
What should be my fouth mod to the car after i/h/e ? I was thinking cams or an intake manifold...any advise ?
"Check that young man for nitrous"
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope)
...Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ...
Old 02-12-2004, 09:40 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Fourth Mod ?
depends i'd say cams probbly but depends on motor goals etc
Old 02-12-2004, 10:23 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: Fourth Mod ?
What car and what motor? Need some more info.
Old 02-12-2004, 10:31 PM
B1SiR6A's Avatar
Re: Fourth Mod ?
92 Civic SiR-II...B16A...Pic in sig
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Old 02-12-2004, 10:53 PM
whtteg's Avatar
Re: Fourth Mod ?
I would say cams, cam gears and hondata.
Old 02-12-2004, 11:02 PM
B1SiR6A's Avatar
Re: Fourth Mod ?
What exactly does the hondata do? Is it anything like an Apex'i AFC?
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Old 02-13-2004, 04:17 PM
whtteg's Avatar
Re: Re: Fourth Mod ?
It is a piggy back system that allows you to reprogram your fuel and ignition tables, it also lets you do alot more than that, and it is better than an Vafc or a safc. Go to www.hondata.com and read about it.
Old 02-13-2004, 05:16 PM
tibby01 tibby01 is offline
you wont see crap with a ported and polished intake manifold unless you are flowing a lot more air into the engine than stock.
Old 02-13-2004, 05:25 PM
B1SiR6A's Avatar
Re: Fourth Mod ?
i was reading up on the hondata in the march 04 import tuner and it seems like the problem i'll run in too with that other than cost is the actual programming and its sounds like its really hard...is it this hard and does anyone advise a DIY type thing on this project..if not is there anywhere that i can buy a programmed hondata ?
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Old 02-13-2004, 05:49 PM
whtteg's Avatar
Re: Fourth Mod ?
No there is no DIY for either the hondata or vafc because you need a wide band and a dyno to tune either one. And no you cannot buy an already tuned hondata b/c every motor, even the same series like 2 B18C1's are going to need to different maps.
Old 02-13-2004, 06:17 PM
B1SiR6A's Avatar
Re: Fourth Mod ?
hmm well neither are good for me in that event cuz there are NO dyno's in nassau.(at least none that I know of)
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Old 02-13-2004, 06:24 PM
whtteg's Avatar
Re: Fourth Mod ?
Well you don't have to have a dyno, it does help though. But you will need a wide band O2 for sure.
Old 02-13-2004, 06:57 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Yes you do, or else you won't be able to see where your powerband is, or if you actually made power at all, and therefor have no way to tune it. Buttdynos are teh ghey.
Old 02-13-2004, 07:03 PM
well, you can tune it to run SAFELY, just with a wideband o2 sensor.
but sometimes its ok to run a little rich to gain some more power in certain areas.
i would go with a short throw shifter if i were you. or a set of wheels possibly.
Old 02-13-2004, 07:09 PM
Re: Fourth Mod ?
Tuning implicates you're going to gain performance, not just run the VAFC. If you don't use a dyno you ca NOT tune it for performance, since you will have NO baseline to compare to.
Does the ebay resistor mod really work?? hoopdaddy6 Car Rumors & Concepts 1 12-17-2012 06:58 PM
Aston Martin GJC1 - HM MOD - Carroll Trust carrolltrust General Discussion 0 10-09-2009 07:50 AM
305 mod suggestions gdawgdb Engine and Transmission 2 05-20-2009 03:05 AM
For Sale Great Car mods for basically any car! Jstone616 Cars/Parts for Sale/Exchange 0 05-18-2009 02:25 PM
