Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 02-12-2004, 08:46 PM
civicsedannonvtec civicsedannonvtec is offline
sr20det help
i read the whole newbie faq thread ...
ok i have a few questions...
I've decided im going to buy a redtop sr20det from osakajdmmotors....
I know i will need the Engine, transmission, alternator, starter, power steering pump, Crank Angle Sensor, ECU, harness, MAFS, and Power Transistor / Ignitor Chip....
I'm going to keep the boost at stock 7 psi..
My 1st question is... What should i buy for the sr, to up the reliability ?????( keep in mind im keeping it at 7psi) What is a must that i should do while i have easy access to the engine
Though i dont want to get too pricey because the engine itself is expensive enough...
my second question is...
Does the sr have a/c? .... (im pretty sure it does..)
and what is involved in setting that up because i live in vegas and a/c is a must!!
i'm going to get it professionally installed so what is a rough estimate
of the labor fees im looking at?? ( does not have to be exact )
I'm 100 % serious on this........ i have the money in the bank just waiting to be paying for this awesome motor...
this is going to happen very soon so any help will be greatly appreciated
THANKS in advance
240 coupe
Old 02-12-2004, 08:57 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: sr20det help
the s-13 is a good choice as for prolonging the engine i say get the fmic and a good radiotor and after market fans to keep the car cool, as for a/c it does come with it, but you have to run all new lines to make it compatable with te lhd of the 240sx..
1
Shift_BOOST
97 s14
Old 02-12-2004, 09:14 PM
fgjkdsfh
thanks for such a fast reply!!
so if i wanted it professionally installed with a/c installed and everything.......What do you think it would be around for labor on estimate for example...... ______ to ______ $
240 coupe
Old 02-12-2004, 09:18 PM
turbo2nr's Avatar
Re: fgjkdsfh
it should cost about about 3k to 5k with the new raditor and fans n i/c
1
Shift_BOOST
97 s14
Old 02-12-2004, 09:27 PM
just for labor??
240 coupe
Old 02-13-2004, 12:42 AM
J_Spec_NiTeMaRe's Avatar
J_Spec_NiTeMaRe J_Spec_NiTeMaRe is offline
Send a message via AIM to J_Spec_NiTeMaRe
Re: ??
Originally Posted by civicsedannonvtec
just for labor??
Labor should be between $1000-1500. The SR has A/C. While you have access to the engine, an aftermarket clutch/flywheel set is nice. For stock boost, the stock intercooler will do you fine. A nice radiator will help in engine life.
Really though, the swap requires patience and limited mechanical ability. I highly encourage trying the swap yourself, as everything is very straightforward. Check out the engine install FAQ from srswap.com.
Old 02-13-2004, 04:23 AM
quikmr2 quikmr2 is offline
Send a message via AIM to quikmr2
Re: sr20det help
civicsedannonvtec : Interested in the SR Swap give me an e-mail at [email protected] and i'll get you a good price for the complete engine and labor. If you want a/c, it can be installed but at a minimal price (minimal price is for parts). If you're in Vegas, i can meet you somewhere and discuss the details with you.
Old 02-13-2004, 05:10 PM
ok cool...... been lot of help guys...
one more quick question..
is there anything i should add to the engine for power while the engine is easily accessible ( at a reasonable price )
IF so..... What ? and how much??
THANKS ALOT GUYS
240 coupe
Old 02-13-2004, 05:22 PM
turbo2nr's Avatar
Re: ...
3' downpipe and turbo back exhaust .. hep the car breathe easier and a intake..
good luck
1
Shift_BOOST
97 s14
Old 02-13-2004, 11:17 PM
how much would the price of those 3 be around?
240 coupe
Old 02-14-2004, 04:19 AM
Re: sr20det help
HKS Downpipe $165
HKS Dragger Cat-back $575
Greddy INtake $100
Old 02-14-2004, 04:20 AM
Re: sr20det help
Do you have a preference in Brand name? Prices vary for different brands.
Old 02-14-2004, 09:33 PM
No not really...I'm just looking for intake , downpipe , and catback that gets the job done well , and is the lowest price possible without sacrificing function or reliability...
with that in mind.... what brands should i go with??
240 coupe
Old 02-17-2004, 05:22 PM
bov
should i put a bov on there also while im at it??... any brand suggestions
240 coupe
sr20det help jest808 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 01-29-2004 04:17 AM
SR20DET //Help\\ youngdrifter_x 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 10 12-16-2003 08:26 PM
sr20det help okitrazsliders 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 11-24-2003 03:17 AM
Sr20det Help!!!! 240SXspeed 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 10-03-2002 03:31 PM
Sr20det Help CanadianG General 0 11-12-2001 05:40 AM
