Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 02-12-2004, 03:30 PM
rhilim rhilim is offline
EVAP canister location on 97 z34
I am receiving a P0441 error code and have checked all my vacuume hoses per the documents I have found on the net. My next step is to look at the EVAP canister, but I can't find the silly thing....can anyone provide me some insight as to where it is located? Didn't seem to find in the Haynes manual, nor anywere on the net. Your help is appreciated!
Thanks
Old 02-13-2004, 05:49 AM
rj18rad rj18rad is offline
I have a 96 z34 and it is located behind the wheel-well of the rear driver's side wheel, at least that is where the Hayne's manual that I have says it is. I have never removed the wheel-well panels to see if that is where it actually is or not. Probably will have to soon since I'm getting a code P1441 which is "EVAP System Flow During Non-Purge". I hope that helps you. It's probably in the same location on your 97.
Where on the net did you get the diagrams of the EVAP system? I need to check all my hoses and I cannot find a diagram for the system anywhere. The one in the manual just shows the basic straight line flow, no locations of any of the hoses. Would appreciate it if you could post links of where you found them.
Old 10-21-2004, 07:28 PM
Nobuddi Nobuddi is offline
That Canister Is Under The Passenger Side Front Fender as For The hoses there Are Three. To get to them pull of the weather guard. and there is no website on this i found this out trying to inspect my compressor in our shop.
Old 10-27-2005, 10:51 AM
ffgus ffgus is offline
Re: EVAP canister location on 97 z34
I have a 97 Monte Carlo and I have a OBD code of P1675. The code means EVAP emission vent solenoid control circuit. The car has also stalled on me when warmed up and in drive. Can anyone please offer me some advise? Thank You.
