Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 02-12-2004, 02:36 AM
Vette4lyfe Vette4lyfe is offline
Car Problems!! Help
Hello everyone...
I am having one major problem with a new 944 i purchused. The car keeps turning off! While driving, i notice no power, and look at the gauges to see the battery lite on along with some other lites. So i pull over and try to start the car, but wont start. After several times trying to restart, it finally fires up. I have power with lites so its not battery issues. I dont know if this means anything, but on my air filter box cover thing, theres a hole on the left where a hose goes that ive seen on many pictures, but mine doesnt have the hose, just the hole. Is that important? where does it lead to? and is this my problem? ne help would be greatly appreciated. Info on the car... 1987 944 Non turbo 8 valve automatic transmission.
[email protected]
Old 02-13-2004, 12:04 AM
YeTi's Avatar
YeTi YeTi is offline
Send a message via AIM to YeTi
Re: Car Problems!! Help
does your A/C work?
sounds like alternator trouble to me. but then again, could it be a bad connection to the ignition coil?
YeTi
Old 02-13-2004, 11:04 PM
Re: Re: Car Problems!! Help
Originally Posted by YeTi
does your A/C work?
Just tested A/C, works great, cold as ice. Also another problem that might be associated with this. When I happen to press the gas pedal a little too hard, my rpms drop and no power goes. It drops to about 1-2000 rpm and jus sputters... until i let go a little and then it flies back up where it was.
Old 02-15-2004, 12:38 AM
YeTi's Avatar
when you have the peddal pressed and it's sputtering, is there any smoke coming from the exaust?
YeTi
Old 02-15-2004, 03:24 AM
This only happens when im driving, never when in neutral or park when i rev the engine. Also, sometimes it happens, and sometimes it doesnt. It happens more often than not. so far i have no way of checkin if smoke comes out seeing that im the driver. But tomorrow ill get one of my buddies to watch for smoke...
Old 02-19-2004, 01:19 AM
Re: Re: Re: Car Problems!! Help
NO unusal smoke commin out of exhuast. problem still happening... Need Help fast.. im starting not to trust me porsche
Old 02-20-2004, 12:59 PM
progeitor04 progeitor04 is offline
Send a message via AIM to progeitor04 Send a message via Yahoo to progeitor04
i have a 1987 porsche 944 non turbo and there suttin rong with my clutch pedal ill press it down but it wont come bak up so i cant drive it since i cant put it into gear if any1 knows wat the prob is itll be really helpful
you fuck with me you fuck with the best
Old 02-22-2004, 07:47 PM
Ben944 Ben944 is offline
Send a message via AIM to Ben944
progeitor04- sounds like you need to bleed the clutch or maybe replace the master/slave cylinder.
Old 02-22-2004, 07:50 PM
thanx ben944
Old 03-03-2004, 12:58 AM
matt944pca matt944pca is offline
Look for a vaccum leak as well. Try replacing the seals on your injectors as well, they tend to get pretty nasty over time.
Old 03-24-2004, 03:31 AM
83-944 83-944 is offline
It's not your problem, Porsche had a technical bulletin about using the hose which connected as a breather for the toothed belts. Turns out that dirty air was being directed into the belts box and prematurely destroying them. Porsche plugged the holes and no more dirty belts. Look below the MAF for a tubing connector on the belt box. Plug it if it was left open.
I could e-mail you a scan of the tech bulletin if you want.
83 - Porsche 944 - daily driver
62 - VW Karmann Ghia - never ending restoration project
95 - Ford Mustang - wifes
Old 03-30-2004, 03:17 PM
kcochr3164 kcochr3164 is offline
I own an 87 924S an 88 924S and an 87 944 Please replace your fuel pump relay. I had the same problem on two of my cars.
