Old 02-12-2004, 03:20 AM
LunchBox's Avatar
LunchBox LunchBox is offline
Send a message via AIM to LunchBox
The B16 is finally mine, almost...
Okay, I finally got enough stashed away, and found a great deal on the B16. It's from a stock 2000 civic si, and only has 7000 miles on it (yes, that's the correct mileage). It was pulled from the car in order to perform a swap. It comes with all of the essentials; engine, tranny, ecu, axle, harness. Oh, and I already bought the Hasport mounts, so there's no worry.
My question is this; in my 98 ex coupe, will the provided axles, and assuming they give up the linkage with the tranny, I shouldn't need any additional extenders, or converters... will I? Also, since I'm already wired for vtec, I don't need to worry about additional harnesses that the one that it's coming with, do I?
Reason I ask is I've only got a little bit extra left after the engine, and I' don't want to have to suddenly spend a grip more on the small stuff that adds up fast.
Additional swap advice is welcome too. I'm planning on doing it with my friends in their Uncle's garage, so any and all tools will be available.
Oops, forgot, it's also gonna get a compression test when I go to pick it up. What consistency (or inconsistencies), should I keep an eye out for? Numbers, ranges from stock, what stock is (if it's not the 10.1 I've always read), and differences between cylinders.
Thanks all!!!
R.I.P. SLS "Youngin'", we'll miss you always!!!
"To Each Their Own" - Me
"You can take the racer out of the street, but you can't take the street out of the racer!" - Me
Old 02-12-2004, 04:11 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: The B16 is finally mine, almost...
You should be alright there as long as you get the shift linkage. And yah, you won't have to worry about any harnesses or anything. As for the compression test. I don't know what numbers to look for, but i've been told that aslong as the numbers are consistent across all 4 cylinders you should be alright there.
Empty Pockets Racing Member #1
Old 02-12-2004, 04:54 PM
94civic's Avatar
94civic 94civic is offline
yeah for the compression as long as there isn't a 10% or more variation between each cylinder then you should be fine.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 02-12-2004, 05:01 PM
lorddarkice's Avatar
lorddarkice lorddarkice is offline
consistant is good, just look for unusually low #s. i'm not sure about hondas but i know that the SR20DET's normal compression is 210 210 210 210. but its turbo so maybie the honda should be a lot higher? at any rate just look for consistant #s.
1990 Honda Civic Hatch - 3 motors, SOLD
1998 Honda civic EX - nothing done, SOLD
1990 BMW 325IS SOLD
1992 Plymoth Laser RS SOLD
1992 Mazda Pro-to-gay Given away
1995 Saturn SL2 SOLD
2002 Toyota Camry LE V6 bone stock.
Old 02-12-2004, 05:25 PM
dealgrabber2002 dealgrabber2002 is offline
Send a message via AIM to dealgrabber2002
AWWWW!!! man... you should get my B16A2!!! darn it...
but the way...is it a B16A1 or B16A2?? i know one use cable tranny and the other use hydralic tranny... the one i bought my brother B16A2 is hydralic tranny...MY STUPID BROTHER IS A PUNK..SHOULDA MAKE UP HIS STUPID MIND BEFORE ASKING ME TO BUY IT!!!! AWWW!!!
Old 02-13-2004, 01:21 AM
LunchBox's Avatar
Hey, thanks for the help GSCivic7, you've helped me out on a couple posts now. 'Preciate it!
Old 02-13-2004, 02:24 AM
GScivic7's Avatar
What I am here for.
