Old 02-11-2004, 10:12 PM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
1 ohm stable?
What would happen if I tried to hook up a Zapco 350 to a parralleled dual 2 ohm voice coiled sub? Would it handle a 1 ohm load or is it better off at 4 ohm? thanks
Old 02-11-2004, 10:21 PM
Spectre927's Avatar
BTW its a 10 inch L7. The amp puts out 330 bridged at 4 ohm... and the shop set it up at 4 ohm, so Im thinkin thats the way to leave it. Maybe I should get 2 subs and larger amps since Im really just looking for more power.
Old 02-11-2004, 10:35 PM
tibby01 tibby01 is offline
check the amp manual...it should provide you with the lowest impedance the amp can handle. just remember though, a lower impedance will put more stress on your amp, so your still decreasing its life expectancy.
Old 02-12-2004, 12:17 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: 1 ohm stable?
No, leave it the way it is wired. That amp can't handle a 1 ohm load. And you are starving that sub the power it needs. They are recommended at 600 watts and you are only feeding it a little over 300. Get a bigger amp, I'm sure you don't need a second sub.
Empty Pockets Racing Member #1
Old 02-12-2004, 08:25 PM
yeah, those solo barics take power to sound good. give it some!!!
