Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-11-2004, 06:08 PM
Hellraiserrob Hellraiserrob is offline
Question Turbo for Lewd! (dependable??)
I have a 95 lewd with a H22A1 it has just about 140k miles on it, runs very strong (no smoking, knocking) and very well taken care of. I was thinking about putting a turbo on it right now, and run 6-8 lbs of boost. I want to know if done right will the engine keep on going for another 100k. Hoped out there has some kind experience with this kinda thing.
thanks
ROB
Old 02-11-2004, 06:23 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
I dont have first hand experience with turbo-ing ludes, but ive heard that the h22 isnt good for turbos...If you want it to last on 6-8 pounds for 100k miles then youll have to put a nice set of rods, pistons, probably valve springs and valves, and maybe even a sleeve job. CAuse on stock internals youll never last for 100k.
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 02-11-2004, 06:30 PM
Re: Turbo for Lewd! (dependable??)
Well I know that people say that H22a are not good for boosting because of the high compression ration (they were mostly made for all motor not forced induction) but if I upgrade the rods pistons and a valve job, (if smart lower compression ratio) I would think it would be easy to run run 10-12 lbs of boost daily, and 14-16 for the track. I know this is extremely hard to guestimate but if done right and not "too" abused how long you guys think it would last?
Old 02-11-2004, 07:31 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
It will run fine and last 100K on low boost providing you have it tuned correctly. I have a buddy who is boosting 14 psi on a stock h22a (race gas) and making around 430whp. Not completley advisable, but it can be done. Boost doesn't hurt the motor, bad tunes do.
Old 02-11-2004, 07:53 PM
PunkAlex's Avatar
YEah man, with upgraded internals (dont forget headgasket!) and a lower comp ratio you can run it with that boost all day long. I was just saying the unrealiablility of it with stock internals. Build your motor right and it will last longer than it would in stock form!
Old 02-11-2004, 08:06 PM
Another question... Would the stock fuel system be alright with just 7-8 lbs of boost??
Old 02-11-2004, 08:32 PM
PunkAlex's Avatar
Nah.....youll more than likely need 440cc injectors and some form of fuel management. Maybe a new fuel pump.
Old 02-11-2004, 08:51 PM
Another Question... Do you guys know what kind of Turbo would work the best for my application... I've asked around most of em said T3 or the T3/T4 Hybrid not quite sure what would be better... Any ideas??
thanks
ROB
Old 02-11-2004, 09:28 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Re: Turbo for Lewd! (dependable??)
try a 67trim may be a t04e with a 67 trim you want some thing that flows at least 450lb/min.. tha will give you room to make at least 450hp, fuel mods, 255 in tank. adj, fuel pressure regulator, fuel rail to go with the 450cc+ injectors, and a s-afc to tune it also look into msd for ignation system..
1
Shift_BOOST
97 s14
Old 02-11-2004, 10:41 PM
tibby01 tibby01 is offline
bah...s-afc is poo poo for fuel management on a turbo car. after reading up on the hondata system a bit, i would get that over everything else if you still want a nice idling everyday street car.
Old 02-12-2004, 12:22 AM
Isnt the hondata system quite spendy... I understand putting a turbo on your car isnt exactly cheap but I am just lookin to get a some boost goin until I can afford the whole Shabang
Old 02-12-2004, 02:23 PM
Jermonsta's Avatar
Jermonsta Jermonsta is offline
Send a message via AIM to Jermonsta Send a message via MSN to Jermonsta Send a message via Yahoo to Jermonsta
yes engine management in general is very "spendy", and i would suggest a small turbo, i plan on using a garret gt28, the disco potato, it should work great on an h22
Current ride: 92 civic lx sedan, stock as it gets and stayin that way!
Looking for: 4th gen(93 - 95) Prelude VTEC.
Plans for it: Rebuild the engine and the car, then turbo it with a disco potato(gt28).
Then kill all the mustangs and camaros i see
If you are bored IM (or email) me:
AIM: Jermonsta
Yahoo: Jermonsta
MSN: [email protected]
"Humvees don't drift. Don't ask how we know."
Sgt. Erik Houghton, a runway and alotta sand, Iraq.
Old 02-12-2004, 08:31 PM
fuel management is the most vital part of a boosted car, and is often not addressed properly or sufficiently. dont cheap out on it.
Old 02-12-2004, 08:42 PM
turbo2nr's Avatar
hondata=$$
thats why i suggest the safc..
1
Shift_BOOST
97 s14
Old 02-12-2004, 09:46 PM
Jermonsta's Avatar
go all out, if you are gonna tune it and expect it to live you have to be able to manage every thing, timing, spark, fuel, air, boost, i'm planning on just forking over the $$$ for an AEM EMS, about $1000, but it's a do it yourself thing, tune it yourself on your computer, and make it work
AIM: Jermonsta
Yahoo: Jermonsta
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
