Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-11-2004, 03:06 PM
b16swaper b16swaper is offline
b16b swap
I am looking to do a b16b swap into a 94 civic. I need some info. on things like wire harness hook ups and anyhting else you have to change from the rhd built motor to fit a lhd vehical. HELP.
THANKS!!!!
Old 02-11-2004, 04:32 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Ask Ricochet if you have questions about a type-r swap...that's what he has, a B16B.
Old 02-12-2004, 04:31 PM
dealgrabber2002 dealgrabber2002 is offline
Send a message via AIM to dealgrabber2002
Re: b16b swap
what does it come with? fi they don't know what it come with..it is hard to info you...
btw..how much you get the B16B for?
Old 02-12-2004, 10:41 PM
Honda God
You don't need to worry about the motor not fitting "because it was a RHD motor..." PLENTY of people have JDM motors, and ALL JDM motors are RHD. It will drop in and hook up just the same as if it was from a LHD usdm car (expect we never had the B16B, lol). It should come with the motor, tranny, ecu, and drive axels. I know some companies swaps don't come witht he axels (you'll need them, so if it doesn't, you'll have to pic up a pair). It should definatly have the engine, tranny, and ecu though. And don't worry about the motor being JDM...it doesn't make a lick of difference in terms of how to install the motor the ease of installing it. It still mounts to the same spot in the engine bay, the tranny still mounts to the same spot, the ecu...etc..you get the pic...LHD-RHD doesn't effect motor placement.
Old 02-13-2004, 02:24 PM
The engine I am getting (have not placed order yet) comes with everything.>
Engine -Transmission -ECU -Intake Manifold -Fuel Rail and Injectors -Throttle Body -Throttle Cable- Exhaust Manifold -Alternator -Distributor -Starter -Clutch -Clutch Pressure Plate -Flywheel -Drive Axles with Intermediate Shaft -Shift Linkage -Engine and Transmission Mounts
Am I missing anything here that you guys think I need for the swap?? I am getting new mounts (Hasport) once I order the engine. I know the engine will fit, i am not concerned about that. I was just concerned with the wire harneses and electrical stuff matching up is all. Any comments or suggestions for the swap would be great! Thanks!!
Old 02-14-2004, 01:40 AM
Honda God
Re: b16b swap
You'll probably have to create a wiring harness so the OBD-II motor and ecu can wire up to your OBD-I car...You have pretty much what a motor should come with...also, you shouldn't need hasport mounts (unless you actually want new mounts). The mounts you have should work, just like they do for any other b-series.
