Old 02-11-2004, 02:40 PM
violator6090 violator6090 is offline
Angry Serious Turn Signal Problem!
for the past few months my turn signals have been acting weird as hell...sometimes they work and lots of times they dont. Its not the bulbs because they still lgiht up when i lock or luck my car. and the bulbs in the back are fine as well. When i flick the switch to the right or left my turn signal light comes on but doesnt blink. im guessin i have some electrical problem but my dealership wasnt much help...any idea what i should do?
Old 02-11-2004, 03:39 PM
JOEROC JOEROC is offline
Send a message via AIM to JOEROC Send a message via Yahoo to JOEROC
Re: Serious Turn Signal Problem!
sounds like you have a bad flasher. its located in your fuse block under the dash there usually yellow or blue or sometimes metal do your 4 ways work??
try switching the 4 way flasher with the one for the turn signals and see if that works.
Old 02-11-2004, 04:06 PM
what are 4 ways?
Old 02-11-2004, 04:50 PM
rccat's Avatar
rccat rccat is offline
Your 4 ways are your hazzard lights.
In some cars you have two flashers one for your 4 ways and one for your turn signals.
To find out witch one it is pull it out then you should have no lights on your turn signals and the other one for your 4 ways. your car may only have one
The flasher is a cylinder shape.
If that isn't the problem check all the sockets for your light bulbs yes even under the dash if they are dirty (badly) this can cause the problem
Old 02-11-2004, 07:04 PM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
I bet it's the tumbler in the turn signal lever itself. I had to have that replace on my 95 V6 before...
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
Old 02-11-2004, 07:35 PM
yea its def electrical when i do the hazards they blink...
Old 02-11-2004, 07:38 PM
or the tumbler like blkcamaro says
Old 02-11-2004, 09:03 PM
BadAzz240's Avatar
BadAzz240 BadAzz240 is offline
Send a message via Yahoo to BadAzz240
u sure its not the bulbs dude.. cuz i have the same problem where he light comes on and doesnt blink but the lights for the alarm and the flashers still come on... And it is the bulb there is two bulbs in those fron lenses the easiest way to get to them is leave your headlights on in the up position and take the shrouds off and reach down and unplug the lights from there and try new ones, I bet its the same that was wrong with mine... The lenses have cracks around the outside where u cant see unless you take the whole unit out...and moisture gets in there and the bulbs burn up. So check this first cuz its the easiest and most common thing I have heard of...Good Luck
Just for the Stroke of it...
Old 02-12-2004, 08:57 PM
rccat's Avatar
look in the socket while your there make sure its clean
Old 02-12-2004, 11:18 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
usually there are two flashers on a car. one for turnsignal and one for four ways. That test is not really that realible
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 02-15-2004, 09:04 AM
Marr-TA Marr-TA is offline
I had a simular problem and it turned out to be the socket. I had to pull the wires out and clean the contacts.
Old 02-15-2004, 12:09 PM
tomminajar's Avatar
tomminajar tomminajar is offline
What year car ? Make SURE you have the correct bulb in the socket! Just be cause it goes in doesn't mean it is right.... Can you see all the light flash w/ hazzards on ?
Have fun ! (I hate fixing turn signal lights, Thats why I never use Em')
Old 02-15-2004, 09:33 PM
alright it was the bulbs they were fried...a cleaned the sockets and switched them and they are working fine now...but the problem is not solved because i know it is going to happen again, when i opened up the area to take out the bulbs it was soaked and water actually poored on my face. how and why is water getting in there, what can i do to stop it
