Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 02-11-2004, 02:31 PM
thirdoutoftwo thirdoutoftwo is offline
97 cluster swap
my 97 doesnt have a tach. i was wondering if i got a diff cluster with a tach if it would work or am i just wasting my time?
Old 02-12-2004, 02:13 AM
NeonStyl NeonStyl is offline
Send a message via AIM to NeonStyl
Re: 97 cluster swap
Yes, get another Neon cluster with a tach in it. Swap over your odometer if you like and install it in. Easy as that. Most all Neons, except some early 1995 models already have the tach wire installed in the harness from the factory, even if the car came with a tach-less cluster.
L8R,
~NeonStyl
- www.neonspeed.com -
Old 02-12-2004, 11:13 AM
98JADENEON's Avatar
98JADENEON 98JADENEON is offline
yep the tach cluster will fit just fine. i went the other way with mine. a friend did not have a tach in his and i did so we swapped that way i could install my autometer monter tach with shift light. his car was a 96 and mine a 98 so going from 95 to 99 should all work fine. check e-bay or a junk yard. should be able to find one for under 50
Flowmaster, Iceman, 55mm AF/X TB, Front and Rear BOMZ Racing Strut Tower Bars, Prothane MM inserts and Total Bushing Kit. Carbon Fiber RX300 Tails, .
http://www.slateracing.com
http://www.dmvrscca.org
