Old 02-11-2004, 01:34 PM
annointed annointed is offline
Send a message via AIM to annointed Send a message via Yahoo to annointed
'88 Civic both reverse lights out
My '88 Civic hatchback (1.5L, 4 speed manual) needs to go through inspection, and I just discovered that neither back-up light illuminates. I tried replacing the bulbs, but this did not fix the problem. The wiring diagram shows a backup light switch, so I ordered one from my local dealer for $25. Where the heck is this switch, and am I correct in assuming that this probably the problem?
Thanks.
Mark
'02 Subaru WRX - 326 whp/320 ft-lbs
'94 Subaru Impreza L AWD w/jdm WRX motor [email protected] (14 psi)
'91 Nissan 240sx (soon to be Silvia )
'88 Honda Civic hatchback 1.5L of NA fury
Old 02-11-2004, 01:53 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
Ya, the switch is prolly the problem. I think it is located somewhere on the top of the tranny.
KoRnSaQ
Old 02-11-2004, 02:21 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Re: '88 Civic both reverse lights out
Yah same problem here...its on the tranny, not exactly sure where though. I haven't bothered fixing it though.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 02-11-2004, 02:44 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
..I"m guessing its not something as simple as a fuse?
SOLD!
Old 02-11-2004, 03:01 PM
Re: Re: '88 Civic both reverse lights out
Well, I didn't actually pull the fuse, since the same fuse controls the blinkers, and they work fine, so I ruled out a bad fuse.
But you're right, its funny how often you'll go through hours of electrical troubleshooting and frustration, only to find out a fuse was bad I know I've been there before.
Old 02-11-2004, 04:13 PM
hitr99 hitr99 is offline
theres two wires that come off of the tranny and plug into the harness. check those wires out. samething happened to me and i just wiggled them aroung or unplug them and plug them back in.
Old 02-11-2004, 10:45 PM
lilol89crx lilol89crx is offline
yeah double check the reverse switch. the wires on the switch are just soldered on. they could have broken off. the switch is located on top of the tranny right next to the transmission breather hose. it has a black rubber boot over it.
Old 02-12-2004, 12:17 AM
OK, dumb question here, but is the backup light switch easier to access from under the car (I'm assuming) or is it easier from inside the car, from the base of the gear shifter?
Old 02-12-2004, 12:53 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Re: Re: Re: '88 Civic both reverse lights out
No... it's in the engine compartment... looking from above the engine, it would be directly below the distributor... about 3 inches behind where the clutch cable connects to the transmission... about 2 inches in front of the starter motor... two wires that don't look very special, and are connected individually... but both go right into the reverse light switch that goes into the 'top' of the transmission housing.
Or would you prefer a picture?
Honda Enthusiast
Old 02-12-2004, 02:09 AM
id offer a pic if i had time today to take one.....
Old 02-12-2004, 08:46 AM
Magik Si's Avatar
Magik Si Magik Si is offline
Re: Re: Re: Re: '88 Civic both reverse lights out
A picture would be awesome...because I have the same problem with the girlfriends 90 DX 4Dr assuming it would be in the same place on an ATranny?
Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Old 02-12-2004, 10:28 AM
Doh! Of course, this is a FWD car (my first one I've ever owned). I am so accustomed to longitudinal transmissions, that I completely forgot that this is a FWD transaxle, and is therefore in the engine bay.
Oh well, it was after 1 AM, and I was buzzed on Absolut when I posted, so at least I have an excuse I'm going to run outside and check the switch now...
