Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-11-2004, 02:28 PM
annointed annointed is offline
Send a message via AIM to annointed Send a message via Yahoo to annointed
Question '88 Civic, no reverse lights?
My '88 Civic hatchback needs to go through inspection, and I just discovered that neither back-up light illuminates. I tried replacing the bulbs, but this did not fix the problem. The wiring diagram shows a backup light switch, so I ordered one from my local dealer for $25. Where the heck is this switch, and am I correct in assuming that this probably the problem?
Edit: Car is a 1.5L, 4 speed manual tranny
Thanks.
Mark
'02 Subaru WRX - 326 whp/320 ft-lbs
'94 Subaru Impreza L AWD w/jdm WRX motor [email protected] (14 psi)
'91 Nissan 240sx (soon to be Silvia )
'88 Honda Civic hatchback 1.5L of NA fury
Old 02-12-2004, 12:02 AM
cvcc_wagon's Avatar
cvcc_wagon cvcc_wagon is offline
Re: '88 Civic, no reverse lights?
the switch is on the transmission, on the outside probally where the linkage goees inside, not sure what i tlooks like in an 88 but have a look around. that may be the problem, the other more likely, easier and cheeper to fix problem would be a blown fuse. look at the fuse panel under the dash.
~Attention! if you are thinking about a D16A1 swap for your Civic/CRX and don't know where to start go Here. Thanks.~
