Old 02-11-2004, 12:33 AM
benny27 benny27 is offline
Cool engine backfires help
so my engine backfires a lot just when i am speeding up mostly when i start out in first gear. some times in later gears and once in a while when just going a steady 55 to 60 mph.
i know that i have a vacuum leak and need a good tune up.
but how much should it cost to git a vacuum leak fixed and if i did and got the tune up should it stop doing that.
not going to do it myself have some one Else do it so would have to pay labor too
$125 to $150 for tune up i know
it is a 89 s-10 2.8L if that helps
Old 02-11-2004, 02:06 AM
blazinmiller blazinmiller is offline
Backfires are almost always timing issue's.
Make sure you get that dist and timing checked out on your tuneup.
Where's your vaccum leak?
Old 02-11-2004, 02:30 AM
Re: engine backfires help
I'm not sher where it is the reason i know about it is because the mechanic told me I had a pretty bad one. I know nothing about vaccum leaks at all I feel like a dumass for not knowing
he is going to check the timing
dist what are you talking about (I'm probably just having a brain far about that word)
Old 02-14-2004, 03:51 PM
blu night blu night is offline
Vaccum controlsyour timing advance on your distributor, this would make it backfire. Fix the leak and get a tune up should fix problem. Who ever works on the truck will probably charge time and parts. Take it to someone you trust and they will check timing if needed.
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
97 lumina engine acting erratically. aptivaa12 Lumina 5 04-22-2009 09:42 PM
'96 Voyger 3.3L engine backfire badly taskrov Caravan | Voyager 2 06-14-2006 10:46 PM
Engine Backfire on Pass Side Bank NY_Z28Man C/K 5 12-29-2004 09:44 AM
86w/76 engine backfires through carb dan_86surb C/K 4 04-19-2004 05:39 PM
