Old 02-10-2004, 11:45 PM
crx hf crx hf is offline
DOHC ZC into HF with an si tranny and hf hubs/axles
Well i have an hf with a d16,i/h/e/stage 2 clutch and i wanna put in a dohc zc but i dont know if it would fit becouse i still have the hf axles and hubs.But i have an si tranny and the HF axles fit on perfectly fine.So i dont see why it wouldnt fit.I just want your guys' input.Also would my header fit my new engine.
Old 02-11-2004, 07:33 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
Re: DOHC ZC into HF with an si tranny and hf hubs/axles
yeah..as long as you keep the hf axles..you'll be fine..
your i/h/e should all transfer over to the zc just fine..
SOLD!
Old 02-11-2004, 07:58 AM
91civicDXdude's Avatar
the ports wont be perfectly aligned on the header, you might want to port it out for maximum performance, but it will work non ported
Old 02-11-2004, 09:13 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
To port the header, take the ZC exhaust gasket (use an 89 Integra gasket) and lay it up on the header...trace the ports onto the header and then ream them out with a dremel tool or something
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Hub and Bearing Axle Nut Torque Number??? dwbailey Explorer | Explorer Sport Trac 3 06-04-2009 08:41 PM
for sale/trade F22a with tranny and ecu, and other extras for accord and prelude XMASTERX87 Classifieds 1 08-31-2007 01:57 AM
CRX with Integra Type R hubs/axles??? chavo Let's get Technical! 7 04-08-2004 12:55 PM
Buying DX axles and hubs! quiXilver '88 - '91 Civic | CRX | Wagon | Shuttlee 0 05-14-2003 06:24 PM
