Go Back   Automotive Forums Car Chat > Saturn > LS/LW
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 02-10-2004, 07:00 PM
pthacker pthacker is offline
Question Service engine Code P1404?
I took my car to the dealership & they ran the dignostics on it($65) and came up with Code #P1404. they said they cleaned the ERG valve and cleared the code. they say they test drove it for about ten miles. Guess what I live twenty mile from the dealership and at 12.9 mile the lite came back on. Is this something I can fix myself, or due i need to take it back and let them fix it?
Thanks TH
Old 02-19-2004, 10:54 PM
altean altean is offline
Re: Service engine Code P1404?
bad transmission...mucho dineros
Old 05-09-2005, 07:34 PM
Pat_OD's Avatar
Pat_OD Pat_OD is offline
whoa whoa whoa what the hell are you talking about? Bad tranny? No way you prob just need to buy a new EGR valve. My scanner keeps throwing the same code out. A new EGR valve for my car is like $100-150 and you'll need to buy an EGR valve gasket, which is a few bucks. Its an emission thing its not going to hurt your car but you should get another one just cause it doesnt clean the exhaust as well and you prob. wont pass emissions.
Old 05-09-2005, 08:56 PM
Talking Re: Re: Service engine Code P1404?
sry..it got to the wrong post...my bad..
as for this post..his egr valve is bad. actually the code comes as a result of the ECM incomplete sensor data.
Old 05-09-2005, 09:15 PM
Pat_OD's Avatar
lol i was gonna say"what u been smokin"
Old 05-09-2005, 11:35 PM
Re: Re: Re: Service engine Code P1404?
hehehe i wish i was smoking some good stuff...lol
anyways...this is it..
P1404 is the EGR Pintle Position (system) and the fault
description is "Circuit Fault".
in reality, the best thing is to take the whole damn intake off and do a good house cleaning,since all the passage ways(i.e. vacuum routes, etc.)gets plugged.
the pintle gets stuck by all the crap inside the manifold, usually having the engine running too rich.
the original culprit is(most of the time) the faulty engine coolant temp sensor.
with that going bad, is usually downhill for performance and everything wise ...lol
now.i think I've exhausted the subject for all the peps...lmao..
Old 09-29-2006, 02:35 PM
Will-n-SD Will-n-SD is offline
I came up with the same error. I did have a bad temp sensor last year and it was fixed along with replacing my cat converter since it was hallow. Now a year later and I get the P1404 error.
So is there a way to test the EGR valve to be sure it is good? What are some easier ways to clean this without tearing the engine apart?
Old 11-12-2006, 10:56 PM
Update on what I did on my car.
I took off the EGR valve. I then took a small screw driver and did a little scraping inside the tube. I then put the EGR valve back on and clear the code. Well a month later and no error.
Old 06-14-2007, 03:35 AM
Talking Re: Service engine Code P1404?
The only thing to do is to take the valve off and give it a good overhaul and cleaning.
95% of the time will work.
In some cases it's just too old and you have to replace the valve anyways.
They're not that expensive and it will save you the headache to fumble around with it if you don't want to get real dirty.. lol
one more thing.. and I strongly recommend against it unless you are really , really desperate..
is to take the valve off and use compressed air to blow right through the passage ways..
there.. if yer engine quits, do not blame me..lmao
Old 06-15-2007, 01:07 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
this thread was been resurrected 3 times, it won't be again.
******CLOSED******
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Service engine code P0442 on Sable Wagon 2001 melodycamp Sable 1 12-03-2005 06:31 AM
Service Engine Codes dsevern Blazer 4 06-10-2004 05:56 PM
Service engine Code P1404? pthacker SC/SL/SW 0 02-10-2004 07:31 PM
Service engine codes and online sevice manual? WR_Dave Vitara 1 01-27-2004 11:32 PM
Deleting Service Engine Code lotto89 Cavalier 0 07-18-2003 11:52 AM
Closed Thread
