Old 02-10-2004, 05:56 PM
GTPpower GTPpower is offline
Question air vents
On my 97 gp, i don't think the air vents are blowing as hard as they should. when the temperature control is on cool, it blows normal, when you turn it to warm, the fan speed still stays the same, but it blows considerably less. It sounds like something is blocking it. Does anyone have this same problem, or is this normal?
Old 02-10-2004, 08:59 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: air vents
Yes something is restricting the airflow! In the cold position the air has to go thru only the evap core and when heat is selected the air goes thru the evap core and the heater core which reduces the air flow. In heat mode the air flow has more to go thru thus you have less airflow.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 02-13-2004, 09:16 AM
Re: air vents
so this is normal for air flow to be restricted that much?
No air flow from vents, blower fan running ts1653 Windstar 5 07-19-2014 02:02 PM
2000 Windstar Air vents not working right olopezm Windstar 11 08-04-2010 10:09 PM
Fresh air vent blowing moldy air, resolution ? Wht4Runner 4Runner/GX470 1 07-01-2005 01:40 PM
97 jetta GLS- air vent and compartment below air vents stolen Laracena Features and Editorials 0 02-06-2005 04:45 PM
Why there's no hot air from the front air vents? sudin36 Park Avenue 0 02-23-2004 02:45 PM
