Old 02-10-2004, 04:21 PM
Imkunfused Imkunfused is offline
Wierd electrical problems
This just started happening on a 96 GL taurus. When you put the car in reverse, the radio shuts off.. you lose power to the items in the door (door locks, window). the lights for the buttons on the doors shut off, and it gets real hard to steer (powersteering working harder). Has anyone had this kind of problem? There are no problems with wires getting pinched from what i can see. Any help would be appricated.
Thanks
Old 02-10-2004, 05:41 PM
dukebonaventura dukebonaventura is offline
same thing has happened to me...
I too have a 96 ford taurus GL and a few months back, the radio wouldnt work in reverse, but that was it, then it worked ok a few weeks later...but the last month or so ive run into the same major problems...The light in the dash that shows that the driver's seatbelt is not buckled will flicker on and off very rapidly, then i will lose the radio, window motors, winshield wiper motors, and the steering will get very tight. When this isnt happening, most of the time my radio doesnt work unless the car is in park. If i come to a sudden stop, or hit a pothole, or accelerate quickly, the radio will come back, which leads me to believe its a wiring problem. A former car mechanic told me the radio part is most likely a wiring issue, but had no idea about the other problems. He thought maybe the Ground on my battery was bad and changed it, but the problem has occured since then. When i took it to my regular mechanic, he said that Fords are notorious for having dashboard light problems, that id have to buy a new radio, and he changed the power steering fluid because it was the original fluid...but i knew deep down it wasnt all a coincidence and now i know it definitely isnt coincidental if it is happening to you too...im off school next week so im going to take it to the dealership, if you find anything out before then let me know, if not ill let you know what the dealer says! Goodluck!
-Duke
Old 02-11-2004, 04:58 AM
michelq michelq is offline
Re: Wierd electrical problems
you have shrorted safty switch on transmission,replace it
michel
Old 02-11-2004, 03:37 PM
Thanks Michel, Hopefully that will take care of the problem
Old 02-11-2004, 06:20 PM
for sure it will fix the problem.
other name for the part
transmission range switch or sensor
Old 04-11-2004, 04:15 PM
angeiboz's Avatar
angeiboz angeiboz is offline
I did my TR sensor my self, it’s really easy (I'm a girl), and the part was only about 40.00. It fixed all my strange electric problems.
Old 04-25-2004, 01:48 AM
CrackALaid CrackALaid is offline
Send a message via AIM to CrackALaid
Just to let yall know, This Just Started Happening to Me This Morning, Same Thing, Radio Cuts Off In Reverse and When I Accelerate Quickly. I'm Going to Buy a TR Sensor Tomorrow, Hope It Works Cuz I'm Broke Afterwards (assuming its 40$)
Electrical Problems...... GaryCifers Corsica 6 01-13-2010 04:08 AM
98 E430 Wierd Electrical Problem tommy_ace E-Class 1 11-24-2009 01:57 PM
98 Astro Van Wierd Electrical Problems pint4 M Bodies 5 03-26-2008 12:32 AM
2001 Malibu wierd electrical problems zooeyhall Malibu 5 10-21-2007 09:49 AM
