Old 02-10-2004, 02:33 PM
91accordguy 91accordguy is offline
rotor help
hey guys, i need help getting my rotor off. I dont know how to take it off. Thanks
Old 02-10-2004, 08:40 PM
jusg19 jusg19 is offline
front or back? rotor or drum?
front: take off the tire, remove the caliper top and bottom bolts, remove the caliper/pads cradle (there should be 2 14mmish bolts on the back side of the cradle), then there may be two screws that hold the rotor to the spindle (its between the lug threads) drill them out if you have to, then take a hammer and knock the rotor off
Old 02-11-2004, 02:50 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Re: rotor help
you can also use a bolt (10mm?) to screw the rotor off the hub....the other two holes (not where the scrws are) will allow you to put a bolt in them...it kinda works like a pulley puller...as you screw in the bolt, the rotor moves out on the threads away from the hub
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 02-11-2004, 04:08 PM
the bolt works if: the threadholes aren't rusted badly and you have 2 screws, I've bested screws off in the holes everytime. If your not keeping the rotor take a big hammer and wale on it.
