Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-10-2004, 12:49 PM
andera andera is offline
Send a message via AIM to andera Send a message via MSN to andera
painting charge pipes
Hey has anyone here painted their charge pipes on a turbo'ed car? What kinda of process does this take? What kind of paint? Do you need some kind of enamel? Thanks!
Old 02-10-2004, 01:54 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
You could powder coat them and they would stand up to the heat, but if you want a more glossy metallic finish then anodized paint would work great and can stand up to the heat. You can buy anodized paint from most any place that sells paint and Krylon is a good brand to go with.
Old 02-10-2004, 01:56 PM
Re: painting charge pipes
Thanks Polygon. Off the top of your head do you know if that stuff's spendy or not?
EDIT: anyone know when they say "heat resistant up to 400F" if that means that the paint melts at 400F or if it stops resisting heat at 400F? Also, do charge pipes get much hotter than 1200F? Thanks.
Old 02-10-2004, 05:37 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
If it says "up to 400" then probably wont last too long at 400....if it says somethign like "400 degrees resistant" then it should work....if not sue em! hah hah jk jk
1200 degrees? i hope thats a typo....your engine would be a nice big blob of iron, aluminum, and plastic if it got up to 1200 degrees!
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 02-10-2004, 05:49 PM
I found a paint that'll be fine up to 1500F so that should work. Also, i thought exhaust temps reached 1500+ degrees F...?
Old 02-10-2004, 06:25 PM
PunkAlex's Avatar
Yes, you are right, exhaust temperatures do get up that high, but the charge pipe air temperatures never reach those levels. your manifold/hotside of turbo/downpipe reach high temperatures, but the intake side of the turbo never touches the exhaust.
Old 02-10-2004, 11:29 PM
tibby01 tibby01 is offline
well, it does...because the turbine and compressor housings are connected, but heat isnt transferred well enough to get past 500 degrees(rough approximation).
if you want to do it the cheap way, maybe try some duplicolor paint from walmart. the kind that is heat resistant to 900 degrees or something.
Old 02-11-2004, 12:32 AM
IntegraB18LS's Avatar
IntegraB18LS IntegraB18LS is offline
I can beat the hell out of my car, I am running 5 psi and no intercooler, I have sections of PVC pipe (spraypainted with regular paint) and They hardly even get warm. the only pipe that does get kind of warm is the one next to my throttle body, and that just gets hot because of the engine bay heat. you will be all set with the 400º stuff, but if you get higher temp kind it sure wont hert.
Yes I said PVC pipe, yes i am a hack, yes it works fine, yes it will be being replaced as soon as my intercooler and some mendral bends come in
Kyle
[url=http://www.automotiveforums.com/vbulletin/showthread.php?
1995 Honda Civic EX
-Integra B18B1 LS engine
-Turbocharged
-Rear disk conversion
-Many mods
Cheak out my civic (cardomain)
Easly got 10k into this car with everything and it still looks like a POS
Old 02-11-2004, 04:43 PM
PunkAlex's Avatar
pvc you say? that sounds kinda good...seeing how mandrels are expensive....what other pipings work?
Old 02-12-2004, 10:59 AM
you can use anything you want that can hold a few PSI and doesnt expand to much. I will be getting Mandrels soon, but honistly the PVC is working great although im sure the flow in the bends isnt the best.
My cold side on my compressor never seems to get more then warm, maybe its because you can look through my front bumper and see the turbo (BW bumper, no A/C)
1995 Honda Civic EX
-Turbocharged
-Many mods
