Camaro rear end
Gotta 88 camaro, V8 w/2:93 gears. Was driving along the other day and the engine pulled down and then the rear end popped and started making a clunk noise with every rotation of the tires. My first thought was U joints, but i checked those, and that doesn't seem to be the problem. I"m thinking it's an internal problem with either the ring, or spider gears. i dont know if they chipped a tooth or what the hell the problem is. But if i do end up changing or fixing the differential, i'd like to put in a 3:73 possi unit. My question is, what do i need to know when buying a differential unit? If i remember right, it's got 28 spline axels, and a 3 series carrier, but that's just from what i've read. Please correct me if i'm wrong. My first choice is going to be to buy a used unit off ebay, and my second choice will be to buy a new unit from jegs. I just need to know what i'm looking for when buying a used unit. most of the people that are selling used units say it will fit a camaro, and give the specs on it, but i'd like to make sure i'm getting what i need before i spend $250. thanks
Re: Camaro rear end
well, first, its a 2.73 or 2.77 rear end, no such thing as a 2.93. and a 2.77 is a borg warner rear with 7.75in ring gear. which you would only have on an IROC. so its probly a 2.73 open rear. also, you have 26 spline axles not 28. 1989 and up camaros got the 28 spline axles. you can get aftermarket axles, or steal some from an 89-92 camaro to get em, make sure that if you have drums, you get the axles from drums, and if you got disks, get the axles from a disks equipped car. if you upgrade to 28spline axles, get a torsen unit from a fourth gen camaro, they have 3.23 or 3.42 gears on them, and are better than posi units. a posi is just an open rear end with conical clutches in it to reduce single wheel spinning. a torsn is a internal gear driven torque biasing rear end. farrrrrr better. i got mine on ebay, torsen carrier with 3.23 gears and matching pinion gear for 200 bucks. but you wuold also have to change your axles, so it will be a bit more.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
The gears in the rear end are not original, they were put in the car by one of the previous owners, but they ARE open 2:93's, or 2:92's i'm not sure which. i did the math and it came out to like 2:92.58 or somethin. I dont know if those gears are available, or if they used a different ring gear with the original pinion. i'm not even sure if that's possible. The original gears were 2:73 i think. But anyway, i pulled the cover off today and one of the spider gears was in about 6 peices and the ring gear was chipped. So it's time for a locker. I'm not planning on changing axles, i just needed to know what the spline count was etc. So i can order the the right differential.
Re: Camaro rear end
wow, never heard of those gears before, guess ya learn something new every day. but anyway, you should have 26 spline axles. but while you got the rear end apart, i would go ahead and count em yourself, just in case the previous owner swapped those too.
Re: Camaro rear end
all this rear-end, gear, torsen, posi, axle talk is confusing the hell out of me.
see, I wanna put 3.73 in my RS that currently has 2.73, can i just swap gears, or do I hafta change a bunch of other shit?
Re: Camaro rear end
if so, PM me some details
is there anything wrong with using the conical clutch differential? Dont really have the money and time to get the rear end from a fourth gen. And there's only 2 junk yards around my town, and none of have any fourth gens anyway. I'd just like to have possi with 3:73 gears. It's kinda embarassing to have over 300 horsepower and only leave a peg leg burnout. And Genopsyde, you can change your ring and pinion to have 3:73's, there about $130 from jeg's or summit, or i've seen em brand new on ebay for $100. but it's kinda pointless if you've got an open differential. you wont go anywhere off the line.
Re: Camaro rear end
naw, you can run a conical clutch posi, they are reliable, just not the best. and as far as price, i mean i got my carrier and gears for 195 bucks. Ebay man, ebay
Re: Camaro rear end
ok, so i get some 3.73's and a torsen unit from a 4th gen, is that all I need, or is there more to it now?
Re: Camaro rear end
nope, your 91 should have the 28spline axles, just like the fourth gens. personally i would reccomend a torsen with 3.23 or 3.42 gears already attatched from the factory, but hey if you want 3.73 then go for it man
Re: Camaro rear end
What do you mean?? There is nothing embarssing about doing one wheel wonders. Look at the picture in my sig...Notice how the smoke is only coming from the passenger side
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
Re: Camaro rear end
me likey grand nationals...
well I got a 84 v6 and doing the engine swap as a project thing. Going to put in a 383 stroker so what do I have to do to the rear end to make it hold up under the power?
Re: Camaro rear end
do all 4th gens have torsen?
Re: Camaro rear end
No the earlier one's use Auburn I'm not really sure what year they switched
