Go Back   Automotive Forums Car Chat > Buick > General Discussion
Old 02-10-2004, 11:03 AM
marionh marionh is offline
Low Oil Pressure
Vehicle Information:
1991 Buick LeSabre
3.8 liter engine
215,000 miles
No engine work other than timing chain replacement as preventive
Uses about 1 quart of Valvoline 10W-30 per 4000 miles
Problem: Oil pressure light flickers during low engine RPM after warmup.
I'm considering trying a 10W-40 oil to see if this eliminates the problem. Any comments or suggestions would be much appreciated.
Thanks in advance!
Marion
Old 02-10-2004, 11:48 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
check either the oil puressure sending unit or the wire that is going to it. Also 215,000 miles on it. I would not be suprised if the oil pump has wear to it. It's just one of thoes things that happens.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 02-10-2004, 12:47 PM
Re: Low Oil Pressure
Thanks for the suggestion, Hypsi!
Old 02-10-2004, 02:59 PM
Hypsi87's Avatar
No problem man. I hope it all works out
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 02-11-2004, 10:27 AM
kratefan kratefan is offline
Oil Pressure
Have you checked the coolant temp? My TR was overheating at times and that would drop the oil pressure as well. The temp wasn't enough to set off the light, but it was high.
Jeff
Old 02-12-2004, 12:23 AM
comp comp is offline
check those out, upping the oil wt. proably is good idea depending on
the temp.
Old 02-12-2004, 07:19 AM
Thanks for the responses, all of which provide good food for thought. I almost bought a SW mechanical oil pressure gauge yesterday and decided instead to let a mechanic who I know and respect listen to the engine. He was not in, but his son was there who is also good. I had heard a rattling noise when it was idling from time to time. He pointed out that is was occurring right after coming off of and just before going back to idle. Other than that, he said the motor sounded fine. I had the same shop install a timing chain about 35,000 miles ago, which they recommended because of high mileage. I'll probably take it in and let them find and repair the source of the noise next week. I've also asked him to clean the oil strainer and check the pressure while they are at it. As for overheating, I had the radiator rodded summer before last, and have never seen the high coolant temp light come on except when the ignition is switched on before starting. However, I have noticed lately that I'm losing about a cup of coolant a week, but the engine runs great so I don't suspect a leaking head gasket. I have just over 100k on the water pump, so the seal may be leaking. I need to check that. Interestingly, the oil pressure light has not flickered since I first posted this, but I'm not going to wait to check it out. Thanks again for all the input.
Old 02-12-2004, 03:54 PM
see there you scared it just like a kid not wanting to go to the doc.
Old 02-13-2004, 09:20 AM
I wonder if that would work on my wife?
Old 02-13-2004, 08:36 PM
don't you and millions of other guy's wish, i'm lucky i'm the tough one,
so i got it easy (ok easier) than most
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
