Old 02-10-2004, 07:58 AM
Sean Price Sean Price is offline
Send a message via AIM to Sean Price Send a message via Yahoo to Sean Price
Guys I need your HELP, severe problem or not?
today on my commute to work I noticed that as soon as i hit 60mph that my car starts to shake or more like vibrate? Its not that bad but IT is noticable....
the steering wheel also vibrates slightly due to this shaking? It seems to be coming from the rear? I got to work and checked it out and thru my visual inspection could find nothign amiss?
on Sunday the front brake pads were replaced...but other then that nothing else has been done to it? it drove fine last night.....but then all of a sudden this morning...?
any thoughts or input?
what should i do?
i'm in WI its pretty cold but only like 20f, tires have air....somebody sed soemthign bout balance the little weights?
i'm pretty stumped hope you guys can give some help?
peace
one
Sean Price
keepin it real/packin steeL/gettin high/cuz life's a b*tch and then u die....
Old 02-10-2004, 08:21 AM
Magik Si's Avatar
Magik Si Magik Si is offline
Check the balance but also check and see if there is any snow on the inside of your rim, if for example you drove through a pile of snow at the end of your driveway or a snow drift or something and some snow got lodged on the inside of your rim...it can make your tire act like a washing machine with all of the clothes on one side during the spin cycle...it roll's eratically...thus the vibration...only other thing I might suggest is a bad ball joint or warped rotor...but it sounds like the snow thing to me...
Good luck, hope that helps...when you figure it out let us know what it was...
Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Old 02-10-2004, 10:44 AM
Re: Guys I need your HELP, severe problem or not?
Jason
YOU know I thought that too and mentioned it to people but everyone said that THAt couldn't be it...
but last night I did DRIVE thru crazy snow and got "stuck" and had to forward/reverse to get out finally just leavin it buried in snow...I even showed these people the all the snow on the back tires..which is where it "feels" like the problem is coming from....
hehe but I think YOUR right it probably is that snow...thanks and if NOT i'll be sure to let you guys know..
thanks for the INPUT
peace
one
Sean Price
Old 02-10-2004, 11:13 AM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
I have the same problem, my car drives so bad over 60mph right now because of all the snow, i clean it out and before i get to the end of my street they are filled again.
-Dustin
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 02-10-2004, 01:37 PM
frozen_Joth frozen_Joth is offline
Easily Distracted
Send a message via AIM to frozen_Joth
Just a thought but your tires might be unevenly worn. Happened to me one time.
'92 blue Civic Si
-B17a
-Carbon fiber intake, full exhaust
-Short throw, lowered
Old 02-10-2004, 08:46 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
We see alot of snow packed rims and suspension parts that cause all kinds of pulling concerns at my dealership..... find a smooth, clean stretch of road and clean your wheels out then give it a shot....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 02-10-2004, 09:07 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
One of your wheel weights probably came off. Just have them rebalanced. Unless you have all sticky weights on your rims, which don't usually come off since they are inside the rim and the centrifugal forces holds them on unlike the outer weights which pulls them off.
Old 02-11-2004, 05:59 PM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
vibrating happened to me. first try rebalancing the tires.. another thing to check is the rear bearings. once i replaced that, the ride was quieter and a lot less vibration. to check it, just jack the rear up and try to spin the tires. they need to spin freely and have no metal on metal noise on them
Old 02-11-2004, 06:01 PM
bionictony's Avatar
oh yeah. check for broken cv boots in the front. once i replaced them when they tore, the vibration also stopped.
Old 02-12-2004, 08:41 AM
Magik Si's Avatar
Easiest check is find some smooth dry-ish road...and check and make sure that there is nothing in the wheel (snow)...if it still vibrates...
Then go have your balancing checked...if it still vibrates then you have eliminated the two obvious choices...
Then you start looking at suspension and such...
Wheel bearing's, tie rod ends, cv's, ball joint's, control arms...etc.
It will come down to a process of elimination...if you still can't figure it out...take it to Honda and have them check it (usually free) and then you will know whether you can fix it yourself or if it is something a mechanic has to do...and you will know 'exactly' what you have to do.
Just a few suggestions...
Jason
Old 02-12-2004, 11:56 AM
Jason
Jason
hey all THANKz for all the suggestions those will come in handy in the futu4re I kknow so..
didn't have computer access till now but jus wanted to let you know it was a simple fix IT was all the snow on there and the inside while i was at work all day the snow melted and by the time i drove home it was NOTHIGN but smooth sailing again like i'ma used to!!
thankz yalll
peace
one
Sean Price
Old 02-12-2004, 01:31 PM
Magik Si's Avatar
Re: Re: Guys I need your HELP, severe problem or not?
thankz yalll
peace
one
Glad to hear that you are back to a smooth ride again (and that I was right )...leave it to a Canuck to know what snow can do...eh?
Cheers!
Jason
