Go Back   Automotive Forums Car Chat > Renault > Renault 19
Old 02-10-2004, 06:36 AM
blagg3r blagg3r is offline
Send a message via AIM to blagg3r Send a message via Yahoo to blagg3r
Renault 19 battery drain problem
hi
I have just purchased a N reg 1.4i renault 19 5 door and i am unable to keep a charge in the battery , i have changed the battery for a new one and in 5 hours the battery is dead again ,
are there any known faults that maybe the cause of this
If you need further details plz let me know
Thx in advance for the help
Old 04-06-2004, 02:29 PM
breengin breengin is offline
Try disconnecting the rear window heater as it might be a faulty switch (stuck on), worth a try if nothing else.
Breen
Old 04-13-2005, 03:33 PM
phyton phyton is offline
Re: Renault 19 battery drain problem
Originally Posted by blagg3r
hi
hi first of all check your radio out it is a comoc problem in much of these cases and somtimes the last thing people think abaut also check your sigarette lighter
gl let me now if you find it
Old 11-06-2006, 09:59 PM
RODALCO RODALCO is offline
Fault finding.
If you take the accu lead off does it spark when you reconnect it?
Take out all fuses, be sure which carrier slots they came out from so you don't swap the values about.
Do the spark test each time and narrow it down to the circuit which draws current.
Then it is a matter of tracing the wiring, the on off switches of the item concerned if it is not on all the time.
If you have a DC ammeter you can put that in series to check what load you are drawing from the accu which may give you an idea which may be at fault.
Good luck
Raymond
RF. Meters, Clocks and Trains are great.
Cars give you freedom and stress.
Raymond ,Titirangi, Auckland, New Zealand
