Old 02-09-2004, 08:53 PM
rdawg999 rdawg999 is offline
Question Differences between 1st gen and 2nd gen CRX's
Im looking at getting a CRX but my friend told me I should get a 2nd gen one, but I have no idea what the differences are between the two. Im on a limited budget so I cant just buy anyone. I know the early first gens had receded headlights, and I dont want that. Any other changes? Thanks
Old 02-09-2004, 08:56 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Re: Differences between 1st gen and 2nd gen CRX's
Um... yeah... they are completely different... I would much rather have a 2nd gen one.
The 1st gen ones are very boxy. Plus you can do alot more (and much easier) with the 2nd gen ones.
Old 02-09-2004, 09:01 PM
crx91's Avatar
crx91 crx91 is offline
everything is dif.look at this rex and tell me wich one u want to buy. No but really 2nd gen has way more aftermarket crap out for it. I not too sure if you can swap any vtec moptor into it if you plan on doin this i might be wrong tho.Get a 2nd gen there sexy as hell and not in a gay way.oh yeah if money is no object get a jdm 2nd gen
Old 02-10-2004, 12:28 AM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
my s/n says it all, go for the 1G and ditch these stunnas
www.redpepperracing.com
-Dustin
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 02-10-2004, 09:56 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
My friend bought a 89 CRX SI in good shape for 800 dallars a couple of months ago, so if i were you i would just keep an eye open cause you can get a 2nd gen for a good price if you know where to look
KoRnSaQ
Old 02-10-2004, 01:37 PM
Alright, thanks Ill stick to looking for a 2nd gen. I found someone who wants to part with their 90 si, my friend says drop a zc sohc in it, so I think Im gonna do that.
Old 02-10-2004, 02:07 PM
A SOHC ZC is prety much the same thing as a stock crx SI engine which is a d16a6. I think they have the same HP. So i would stay with the stock engine unless you want to go v-tech or B series
KoRnSaQ
Old 02-10-2004, 02:12 PM
Stop listning to your friend. It sounds like he/she knows the lingo but not the cars.
-Dustin
i wish it was fast
here is my website
Old 02-10-2004, 04:39 PM
travagliante's Avatar
travagliante travagliante is offline
yep put a dohc zc in it. Very cheap. Use the si tranny and axles and ecu, all you need is to bolt the engine in. Plus they can be had for around 500.00 and hp=~125-138~
Old 02-10-2004, 08:31 PM
4GZChatch's Avatar
4GZChatch 4GZChatch is offline
Send a message via AIM to 4GZChatch Send a message via MSN to 4GZChatch Send a message via Yahoo to 4GZChatch
1st gen dohc zc= 129hp @ 6800/106tq @ 5700
2nd gen dohc zc= 137hp @ 6800/108tq @ 5700 rpm
sohc d16a6= 108hp @ 6000 rpm/100tq @ 5000rpm
sohc vtec= d16z6 125hp @ 6600rpm/106tq @ 5200 rpm
D15BVTEC= 130hp @ 6800/about 110tq @ 5200
The 1st gen zc's seem to make their way over here most, which means that the d15bvtec and d16z6 are really just as good a deal, and are much newer in years. The first gen zc's are 88-91's, but the z6 ad d15bvtec are both 92-95's, and deliver the same level of power. Plus, there is not great aftermarket support for the zc, but there is for the z6 and d15bvtec. I just ditched my zc for a z6, and it feels every bit as powerful. The d15bvtec is even a little more powerful, and I can deliver you one for $550 shipped. They are direct bolt-in's, just like the other d-series engines. The only difference is cost of installation is that you have to figure out a way to activate your VTEC, like a VAFC or RPM activated switch, or something. There are inexpensive vtec controllers on EBay for about $60, which will get the job done, so there's no huge reason to go with the ZC. Also, with a ZC, you frequently get a vacuum controlled distributor, which means that you have to buy a 1g teg dist separate, which also means that you have to buy the 1g teg crank angle sensor separate. So, overall, there is no significant difference in price. My $0.02: D15BVTEC is the way to go if you want to do a D-series swap. I have installed a couple of them, and they make the CRX haul some serious A$$!
Remember: You can't spell Crap without APC!
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Hyperco GenII suspension
Progress sway
SAFC
etc. etc.
Old 02-10-2004, 08:49 PM
Re: Re: Differences between 1st gen and 2nd gen CRX's
Ok, but I live in California and I heard from a couple posts on here that you cant swap a dohc into the crx si. Can I swap a sohc vtec in there and still pass visual smog checks? and what kinda 1/4s would I expect from that with basic bolt ons? Mainly im trying to get good gas mileage while getting the most bang for my buck. thanks
Old 02-10-2004, 09:34 PM
4GZChatch's Avatar
You absolutely can swap in a dohc zc, just not the d16a1 which is the dohc from the 1g tegs. As long as you keep your original smog equipment, like converter, etc. If you stay OBD0, you'll do fine. Bang for your buck is still the D15BVTEC. 15's with bolt ons and that motor is easy.
Classic SE-R
GTi-R turbo setup
3" DP
U12 modified ECU
Progress sway
SAFC
etc. etc.
Old 02-10-2004, 10:58 PM
crx91's Avatar
where in cali do you live?I can get dohc vtec motors smoged.I live in L.A
