Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 02-09-2004, 07:51 PM
FastTeen FastTeen is offline
Question can you convert a early model ranger to 4x4??
i was just wondering. i might get one so can you convert a early model ranger to 4x4???
thanks
95 Ford F250 ext cab long bed Powerstoke Diesel, stock. 92 Ford Mustang LX 5.0: Trick Flow R series intake manifold, Cold Air Intake, Throttle Body, Larger Egr Plate, Flowmasters, 3.73 Gears, Off road H-pipe.
Old 02-14-2004, 12:21 PM
Aruba27's Avatar
Aruba27 Aruba27 is offline
Send a message via AIM to Aruba27 Send a message via MSN to Aruba27 Send a message via Yahoo to Aruba27
Re: can you convert a early model ranger to 4x4??
i'm sure you can, you'd have to get a transfer case, and swap the front with a solid axle if it's an older model. those aren't too bad i don't think, but you might have to get custom drive shafts made, and that's expensive. you'll also have to do some work to the interior to get the 4x4 shifter in there. so to answer your question, it can be done, but it's expensive.
Old 02-14-2004, 03:28 PM
EVH5150 EVH5150 is offline
Yeah, they say you're better off buying an older 4x4 than going from 4x2 to 4x4. Not only expensive but it sounds like a nightmare to convert.
