Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 02-09-2004, 06:35 PM
c32b1 NSX's Avatar
c32b1 NSX c32b1 NSX is offline
Send a message via AIM to c32b1 NSX Send a message via Yahoo to c32b1 NSX
blow off valve
i was wonderin what the blow off valve does. i would get it just for the sound and i know it releases the pressure from the turbo. but how does this help?
Old 02-09-2004, 09:16 PM
2turboimports's Avatar
2turboimports 2turboimports is offline
Re: blow off valve
when you close the throttle plate the air rushing towards the engine can't get in. so it would normally build up in the piping and kinda jam the compressor wheel. this would lead to problems over time. so the blow off valve just sits between the turbo and engine venting the incoming air whenever the intake manifold gets a pressure significantly lower than that of the pipe the b.o.v. sits on.
Old 02-10-2004, 05:02 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Sits between the turbo and the exhaust piping out of the turbo
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 02-11-2004, 04:49 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
Re: blow off valve
Thats a waste gate not a BOV.
Anyways when the throttle plate closes under boost it creates alot of pressure between that and the turbo which can bulid up on the compressure and slowing it quickly which isn't good for bearings and exhaust pressure i'd think... the BOV lets off the excess pressure in order to protect the Turbo. Some say a BOV isn't really nessisary.
I disregard my perceived image in the persuit of knowledge.
Old 02-12-2004, 11:26 AM
SaabJohan SaabJohan is offline
Re: blow off valve
Bypass valve (recirculating BOV):
Note that solenoid valves for bypass valves are quite uncommon but it can help reduce leaks in the bypass valve under boost.
Old 02-12-2004, 03:37 PM
Pugbug288 Pugbug288 is offline
Not to highjack the thread but with my buddies Saab 9000 turbo you drive around and you can heard the B.O.V.. But when when in neutral and you rev it up you can't heard it. Im just wondering why you can't hear it.
Old 02-12-2004, 03:56 PM
Re: blow off valve
something about the turbo not producing boost b/c there is no load on the engine.
Old 02-13-2004, 01:33 AM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
Dead on, this was a topic of discussion recently in the turbo forum. Turbo's don't produce boost without load on the engine.
Beer tastes better upside down.
