Old 02-09-2004, 05:41 PM
brockway brockway is offline
No Power to the blower motor
Blower motor was working fine and then all of a sudden it stopped working all together, Blower motor fuse ok, have power to electronic heater control however no power to the resistor or motor but if you run a hot wire to the motor it works. Have also tried replacing the relays. Any ideas or suggestions would be greatly appreciated!!
Old 02-10-2004, 10:46 PM
texmex texmex is offline
Re: No Power to the blower motor
check the connection (should be a red plug) behind the glove box. i had to resolder mine
Old 02-13-2004, 10:03 AM
97chevyman's Avatar
97chevyman 97chevyman is offline
I have a problem on my 97, it will eat the switches, and actually melt them. The problem is the regulator for the blower motor. You now have to buy the entire climate control peice to get a new switch. Replace the regulator while you are at it.
Old 02-13-2004, 10:32 PM
comp comp is offline
what do you have ??? yr.,, model... etc. can be a bad resister block
or??????
Old 02-14-2004, 07:52 AM
A 1991 Chevy C70 which has the same dash as the Chevy pickup. I have figured out that there were a couple fuse's blown that were marked under accessory however the blower only has one speed, which is on high.
Old 02-18-2004, 11:41 AM
mike macintyre mike macintyre is offline
If you have just high blower, your blower resistors are burned out. Its a plug that mounts in the duct work that reduces the power going to your blower motor to get slower speeds. I just did mine, the part cost about $20.
Old 02-18-2004, 10:03 PM
After two weeks of looking into this, I finally found out that my problem was the heater control circuit board had a short which blew a fuse listed under accessory that I didn't realize was connected to the heater itself, had this replaced with a new heater control circuit board and now everything works great!
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
