Old 02-09-2004, 07:42 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
This sux.
Check this out. well my car was messed up, i thought it was the head gasket cause of what it was doin, well this weekend me and my friend were workin on my car, we got the head off then we noticed that i had a burnt valve. Then i remembered i still had a si head. so i threw that on and but the car back together and it was workin great, then all the sudden it started missing like hell like it was before we started workin on it, so i figured we burned another valve or somethin. So know i am figuring i just need a new engine in there. So if anyone has a d15 or d16 that doesnt need to be rebuilt and they want to sell it give me a holla cause i am tired of my car running like SHIT.
Old 02-09-2004, 08:44 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Re: This sux.
I know you didn't mention it directly, but did u put on a fresh head gasket when you swapped heads?
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 02-09-2004, 08:47 AM
ya man, i put new head gasket, new exaust gasket, new intake gasket, cleaned the head and block, and top of pistons, and the valves on the head, replaced plugs. and some other little things, it worked good for about 20 to 30 min then it started missin again.
KoRnSaQ
Old 02-09-2004, 09:58 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
you check the timing?
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-09-2004, 11:52 AM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
Re: This sux.
yea, i was thinking timing.
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Cardomain: http://www.cardomain.com/id/importscrx
Old 02-09-2004, 12:03 PM
Well, we marked the timming before we took off the head and everything, and when we switched the heads we also switched the crank cause the other one was marked, so i know the belt is in the right place. The problem is that the 3rd cylinder isnt firing right, it is missing like crazy, i know the distributer is sparkin it because we took out the plub and it was still sparkin on the head. My ecu is throwing codes 10 and 14 which is the IAT sensor and the IAC Valve, do you think either of tose would be causing it, or do you have any other suggestions. I do have the timming advanced, but it was on normal when it did it last time, so i dont really think that has anything to do with it
Old 02-09-2004, 12:52 PM
GVR-4&a90Si GVR-4&a90Si is offline
Only missing on #3? You check that plug wire? It is much easier for the plug to spark in open atmosphere than under pressure in the cyl.
Old 02-09-2004, 12:58 PM
well, i had just changed the plug wires out last week when the problem started the first time, so i doubt it is them, i just put brand new plugs in it yesterday when we put it back together, i can check the plug later when i get home to see if it is burned up now, but i dont think that is the problem
Old 02-10-2004, 10:24 AM
crxlvr's Avatar
maybe its your cap then.
try taking out the plug wire from #3 cylinder and holding it close to the block, if you see spark then your alright, and you can move onto checking the plug in there.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 02-10-2004, 10:41 AM
Well last night i took out the plug to #3, and it had a little bit of oil on it, so i cleaned it up and put it back in, it still wasnt workin right, but when i started my car this morning it had some smoke but it wasnt missing hardly at all, so i dont know if that fixed the problem, or i think the ring for the #3 piston are about gone cause how else could oil have gotten onto the spark plug??
Ohh, and i have checked the cap and it is firing right.
Old 02-10-2004, 11:31 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: This sux.
http://www.nippon-motors.com/honda.htm for a replacement engine
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 02-10-2004, 08:47 PM
jusg19 jusg19 is offline
Re: This sux.
if your replace the valve cover gasket, you normally get plug hole gaskets too. maybe the gastket there is gone
Old 02-10-2004, 11:22 PM
na, i replaced the valve cover gaskets and gromets(or whatever they are called. It seems to be workin right today, i think with that 1.6 head i just had to ride it a few days to let the valves seal right.
KoRnSaQ
Old 02-11-2004, 07:22 AM
Re: This sux.
do you have and extra d1.6 head? I need a new one for my crx si.
Old 02-11-2004, 07:42 AM
Re: Re: This sux.
I am using the extra 1.6 head that i had, i have a junk 1.5 head that has a burnt valve. I can prolly get you a 1.6 head, i will check around if you need me to
KoRnSaQ
