Old 02-08-2004, 08:50 PM
RxFX101 RxFX101 is offline
Send a message via AIM to RxFX101
Arrow vibration damper (or harmonic balancer) and cam timing question...
been trying to remove this vibration damper for a while now... managed to mess up the timing and now the timing belt has alot of slack in it... the cams to the back of the motor are in time..but the other two up front arent..should i just match the dots? so how should i remove this damper? i tried almost everything besides making a tool for it cuz all my bits are worn and i am outta cutting wheels....
1987 BMW 325i
1988 Audi 90 quattro
1990 Audi 90
Old 02-10-2004, 03:51 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
This should give you what you need http://www.team3s.com/FAQtiming.htm
Resistance Is Futile (If < 1ohm)
Quad-cam Query?????? RVZ05 Escape | Maverick | Escape Hybrid 0 07-05-2010 04:47 AM
Hmm... Damper or No Damper? mightymoose_22 Escort 7 04-10-2009 08:09 AM
Removing Damper to Get to Crank and Cam Sensors Smith1000 LeSabre 8 11-04-2007 09:15 AM
vibration damper question Project_Cav Golf 0 06-16-2006 08:28 PM
How do you keep the flywheel from turning to remove vibration damper? papason Engineering/ Technical 2 07-14-2004 10:35 AM
