Old 02-08-2004, 04:12 PM
SLowell SLowell is offline
Unhappy Failed NO Emissions Test
My 95 Firebird failed its emissions test yesterday....blew away all of the individual components other than NO%. Never had any problems passing in the past and appears/sounds to be running well. Any suggestions on what might be the cause here before I submit it to the garage for who knows how many hours of labour!
Old 02-19-2004, 06:29 PM
95fbodyunder3k 95fbodyunder3k is offline
Re: Failed NO Emissions Test
yer probably goint to have to go to a shop if the engine liht is not cuz u could have bad injectors or cat there is a lot of crap that could couse yer problem
Old 02-23-2004, 08:16 PM
tstokka tstokka is offline
did you have it tested twice? could be a bad test. other than that how are the sparkplugs, wires, egr valve. NOx comes from high heat in the combustion chamber ie, your egr valve isn't opening, or is clogged.
Old 02-23-2004, 11:39 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Try buying some synthetic Carb cleaner and cleaning out the Intake manifold and then take the car to a shop that does high pressure fuel system cleaning, If yours on the east coast Mavis or GoodYears do this for about $ 70.00 and you should be set. If its something bigger than this its usually caused by a failed or missing emission's part
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
