Old 02-08-2004, 04:02 PM
tbond75 tbond75 is offline
Question 2001 Intrigue Keyless Remote
I am looking for programming instructions for my keyless remote. I bought one on eBay and was promised instructions with it. Guess what... I would appreciate any help in locating the instructions. Thanks in advance!
Old 02-09-2004, 12:16 AM
illinoiswronski illinoiswronski is offline
Re: 2001 Intrigue Keyless Remote
search the archives, they are already in here somewhere.
Old 02-09-2004, 08:09 AM
Thanks
I found one for the 1998 model, but it didn't work for the 2001. I'll look again to see if I overlooked it.
Old 03-05-2004, 03:42 PM
aljfoster aljfoster is offline
also need instructions for a 2001 Intrigue
If you find the instructions for the 2001 Intrigue let me know.
Old 03-05-2004, 04:22 PM
Re: also need instructions for a 2001 Intrigue
Will do, but I am not confident. I have been looking for over a month.
Old 07-05-2004, 09:43 PM
wfreeth wfreeth is offline
2001 Intrigue keyless remote programming
This one works for the 2001 Intrigue, I just tried it on 07/05/04 with the origanal remote and my recent eBay purchase.
1) Close all the vehicle doors.
2) Remove the ignition key from the ignition lock cylinder.
Important
In order to successfully enter the keyless entry programming/diagnostic mode, you must complete steps 4-6 within 25 seconds of pressing the door unlock switch.
3) Press and hold the door unlock switch.
4) While holding the door lock switch in the unlock position, Insert and remove the ignition key twice. Do not rotate the ignition lock cylinder.
Insert the ignition key a third time leaving the key in the ignition lock cylinder. Keep the ignition in the LOCK position for the rest of the procedure.
5) Release the door lock switch. The chime will sound 3 chimes, which signals that the transmitter programming/diagnostic mode is active.
6) Press and hold the lock and unlock buttons at the same time on the keyless entry transmitter for approximately 4 seconds. The chime will sound two times which signals that the transmitter has been programmed successfully.
Repeat step 6 for each of the four transmitters. including the origanal one.
7) Perform either of the following final procedures:
Turn the ignition switch to the RUN position.
Remove the ignition key from the ignition switch
Old 07-07-2004, 10:20 AM
paulkramer paulkramer is offline
Ever heard of an Owner's Manual??
