Old 02-08-2004, 03:32 PM
sourgrout sourgrout is offline
low compression in #6 cylinder 5.0 help
Hey peeps I have a 1990 5.0 with low compression in the number 6 cylinder it reads 35lb were the others read 125lbs. This motor has 113k miles and is stock. Anybody know what it might be? just some ideas would help before i go pullin the motor. Thx
Old 02-08-2004, 03:59 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: low compression in #6 cylinder 5.0 help
Does it have a miss? It may be an intake valve hanging open. Hope its not a head gasket leak. Does it smoke? The rings may have gone bad in the #6 cyl. You will hear a misfire if your exhaust valve is hanging open. It could be any number of things.
Old 02-11-2004, 02:00 AM
motor_head_429 motor_head_429 is offline
I agree with 351wStang, I would check the head, and the head gasket, and if that doesn't work, then it could be the rings.
Old 02-11-2004, 11:44 AM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
i assume you mean 125 PSI? that's way too low. i'm guessing you have problems starting and such.
my 4-banger makes 100, 75, 0, and 100 PSI in that order. it doesn't even start and will not stay running even when i try dropping the clutch.
i would suggest rebuilding this motor of yours w/a little bit better internals, and while you're at it change your heads and such. sounds like it's nearing the end of it's life span.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 02-11-2004, 02:36 PM
rerun rerun is offline
actually 125psi isn't that low. it is in the range of running good (but LITTERLY on the bottem).. you have one dead cyl, which is no big deal if its just a beater that you use, but if you race it, or want a perfectly running car then you would want to rebuild it anyway.
Old 02-11-2004, 04:58 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Check to see if its the ring or the head. Either way, you might as well go for a rebuild with that many miles on it.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 02-14-2004, 03:51 PM
351wStang's Avatar
Blame it on the last 13k. I had $13 in my pocket the day I rolled my dad's car. But I was also doing 95mph in a 35mph zone, it started raining and the car wouldnt hold the road in a turn. So maybe it was just my fault? LoL, Young and Dumb!
Old 02-14-2004, 03:53 PM
Re: Re: low compression in #6 cylinder 5.0 help
what kind of car was this?
Old 02-14-2004, 05:32 PM
SkylineUSA's Avatar
Re: Re: Re: low compression in #6 cylinder 5.0 help
A Totaled Car
Old 02-14-2004, 09:34 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Try a cylinder leak down test. Find a spark plug adaptor to put some compressed air in the cylinder when the piston is at TDC with the valves closed. Be careful the engine won't roll over and put about 100 psi into the cylinder. Listen for escaping air out the intake, exhaust, rad cap or oil filler cap to see where the leak is. This might save you an unnessary repair.
