Old 02-08-2004, 02:50 AM
tinpadro tinpadro is offline
check engine light
sorry to sound newb but I ntoiced my 97 gt check engine light will come on if I drive the car like a bat out of hell. once i return to normal speeds it will go off. i know it sounds silly but is a sensor faulty somewhere or is it an emissions thing?
Old 02-08-2004, 09:32 PM
flex339's Avatar
flex339 flex339 is offline
Send a message via AIM to flex339
Do you have a k&n filter on the car?
Old 02-08-2004, 10:12 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
do you have aftermarket headers or an off-road h-pipe?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 02-08-2004, 11:07 PM
Re: check engine light
i dont know what a k&n filter is. there doesnt appear to be any aftermarket things on the car. its all orgininal from my observation. i got the car used and it looks all ford.
Old 02-08-2004, 11:12 PM
flex339's Avatar
The K&N filter is purple thats the easiest way to tell
Old 02-08-2004, 11:18 PM
well the only other way to tell is to take it to a shop with a dtc scanner and tell them when it goes on so they can recreate it if need be. probably just a bad sensor.
Old 02-09-2004, 11:13 AM
Mendari Mendari is offline
Take it to a shop where they can download the computer's error codes. Or you can buy your own On Board Diagnostic Reader (OBD ) for under $200 and you can use it forever.
