Old 02-08-2004, 01:34 AM
96Maro 96Maro is offline
Octane booster?
My car was acting like something was holding it back so i tried some STP fuel cleaner and it has really made a difference. I saw the "NOS in a bottle" in there too. It was the kind for off road use only and it was supposed to boost your gas by 7 octanes. My question is would my camaro run right if i put this in my gas? Someone told me it might run hot or something.
Old 02-08-2004, 01:45 AM
vettemaan's Avatar
vettemaan vettemaan is offline
Send a message via ICQ to vettemaan Send a message via AIM to vettemaan
Nope, would work fine, might give ya a little kick too, just dont use the cleaner and octane boost at the same time. If your looking for a premanant boost for a small price get some good spark plugs and wires.
Old 02-08-2004, 02:18 AM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
Re: Octane booster?
I use the outlaw octane boost all the time with my car and it works real good. I don't hear anymore pinging from the engine.
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 02-08-2004, 01:24 PM
hot_red_z28 hot_red_z28 is offline
Send a message via ICQ to hot_red_z28 Send a message via AIM to hot_red_z28
Re: Octane booster?
You'll be fine using that stuff, but I wouldn't expect a 7 point increase in octane. I forget what the formula is, but someone explained this before, about how you can tell how much it actually ups your fuels octane rating. The number they give you (7) is not usually the same as the number you are thinking of, which is like 87, 89, 92, 93, etc... For example, adding a bottle of that is not going to put you up to 100 octane if you had a tank of 93 octane gas. It will however up it a little.
My Project Write-Up
Old 03-03-2004, 10:47 AM
67ratcamaro 67ratcamaro is offline
Re: Octane booster?
Unless you do any timing mods or a chip you don't need any more than 92 or 93 octane. Using a higher octane fuel than you need may actually reduce hp, due to a slower burn rate. Also, check to make sure the offroad stuff is compatible with your Cat and o2 sensors. If it isn't you'll be looking at some really expensive repairs.
Old 03-03-2004, 09:51 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Octane booster?
my friend put that stuff in his rx-7 and it made the engine actually run worse. dont know if it was that the stuff doesnt work or if just doesnt work with rotaries, but they are supposed to love the octane...
Old 03-04-2004, 10:24 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Re: Octane booster?
Exactly! Even 93 might be too much on some cars, my car runs best in 89 even with advanced timing and such. You wan to run the lowest grade octane possible without detonation.
Also the 7 point increase is bull! Like started before, running 93 octane and octane booster will not get you 100 octane, but more like 93.7 octane.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 03-06-2004, 11:36 PM
bduff509's Avatar
bduff509 bduff509 is offline
Re: Octane booster?
You're right ,HiFlow. I searched "octane boosters" on the net once & found that myself. I even found some home brews. I don't think I'd try them in a street car though.
