Old 02-08-2004, 12:50 AM
Kinked210's Avatar
Kinked210 Kinked210 is offline
Send a message via MSN to Kinked210
Loud raddling noise in first gear...
Yet another problem with my car that I'm trying to get fixed...
Towards the end of first gear (after about 3k rpms) and early into second gear my car starts making this loud raddling noise...its very annoying!
It has always done it since I bought it but it seems like it just got louder or something..and it does it more often now... (sometimes it doesn't do it at all). And it doesn't make this noise in 3rd, 4th, or 5th..just 1st and occasionally 2nd...
A mechanic told me it was a throwout bearing making the noise...if this is it..how do I fix it? Do I have to get all down & dirty with my clutch?
1996 Honda Civic Ex
D16Y8[SOHC VTEC]; 5-spd
AEM Short Ram Intake
DC Sports 4:2:1 Header
Tsudo N-1 Midpipe
Old 02-08-2004, 11:36 AM
95civicCX's Avatar
95civicCX 95civicCX is offline
Re: Loud raddling noise in first gear...
If it's the throwout bearing, then yes it will require getting "all down and dirty" with your transmission to reach the pressure plate which will then allow you to get "all down and dirty" with your cluth. Have fun if that's the problem(You may want someone else to do it).
95 Honda Civic CX
SOHC VTEC
AEM High Flow Fuel Rail
B&M Adj. Fuel Pressure Modifier
B&M Fuel Pressure Guage
APEXi Exhuast
Del Sol Shifter
B&M Shift Stabilizer
H&R Race Springs
KYB AGX Adj. Struts
Eibach Pro Control Front Strut Bar
Arospeed Rear Upper and Lower Strut and Tie Bars
26mm Sway Bar
Rear Disc Brake Conversion (4 Tony)
Specialty Products Adj. Camber Kit
16 Inch Quantum Tec Alloys
215/40 Nitto 450
Old 02-08-2004, 11:51 AM
Kinked210's Avatar
Damn that sucks...you think that's the problem then?
1996 Honda Civic Ex
Tsudo N-1 Midpipe
Old 02-09-2004, 08:45 PM
littlen21 littlen21 is offline
hey kinked i have a 1994 civic and had the same problem i think does it do it when you stop and going slow? If that is the case then it is your heat shield clamp the thing u have to do is buy a new metal band or clamp and clamp it back on to the frame
Old 02-10-2004, 12:47 AM
Kinked210's Avatar
You can only hear it when the clutch is engaged when I'm stopped...and at the end of first gear.
I took my heat shield off so I don't think thats it...also I had another mechanic look at it..he said it was a bad throwout bearing as well...he said its a bitch to replace... :/
1996 Honda Civic Ex
Tsudo N-1 Midpipe
Old 02-10-2004, 01:26 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
i can't reassure you that it's the throwout bearing, but if it is you can count on paying about $400 to get a mechanic to do it. But, if you can successfully unbolt your tranny and remove the clutch, flywheel and pressure plate, you can replace the throwout bearing yourself. And it'll save you a few $100.
Empty Pockets Racing Member #1
Old 02-10-2004, 02:26 PM
MrCrazy's Avatar
MrCrazy MrCrazy is offline
just change the clutch, but by proffesional mechanic. dont have it done by a friend. youll hate yourself if he fucks up.
Old 02-11-2004, 12:30 AM
Kinked210's Avatar
if i pay that much to get my clutch taken out..im gonna replace it with a stage2 >: )
if i get a whole new clutch (mine is pretty worn out anyway) do i still have to replace the throwout bearing? and how much do u think it would cost for an entire clutch replacement (just to replace..assuming i have the clutch)
1996 Honda Civic Ex
Tsudo N-1 Midpipe
Old 02-11-2004, 04:57 AM
GScivic7's Avatar
you don't necessarily have to replace the throwout bearing, but you might as well while everything is apart. Kinda like how it's kinda stupid to just replace 1 spark plug, you might as well replace them all. I would plan on spending about 400-600 depending on the cost of parts.
Old 02-12-2004, 12:09 AM
95civicCX's Avatar
Why wouldn't you replace the throwout bearing, if that's what the problem very well could be....? Your clutch kit should come with a new throwout bearing anyway, so yeah I'd go ahead and change it......If I were you.
95 Honda Civic CX
SOHC VTEC
APEXi Exhuast
Del Sol Shifter
H&R Race Springs
KYB AGX Adj. Struts
26mm Sway Bar
215/40 Nitto 450
