Old 02-07-2004, 02:37 PM
sting-ray sting-ray is offline
Angry 1993 grand am wont start tried everything
Hi, this car has been sitting awhile, when we try to start it it makes a clicking sound. I got a new battery. I took out the the starter and cycloid had it checked at auto zone,checked to make sure the engine was ok and even checked the spark plugs. I even checked the ground wires to the cycloid. I'm out of things to try hope someone knows whats wrong with this car.
Old 02-07-2004, 06:25 PM
JOEROC JOEROC is offline
Send a message via AIM to JOEROC Send a message via Yahoo to JOEROC
Re: 1993 grand am wont start tried everything
check the starter & ignition relays located on the firewall do they click ?? if not take a test lite hooked to ground and probe the hot wires and see if it clicks then. and check your fuses. also make sure the motor isnt locked up. good luck and keep us posted
Old 02-07-2004, 07:28 PM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Try all relays like joe said and check the ign fuses (ignition fuses) or inline fuse for ignition systems.
If the fuse aint working it wont spark. If the power wire that supplies the fuse relay with power is loose it may be the problem as well , if thats the case you could use a 8 mm socket and driver to tighten it hard hand tight. Hope thats a few extra possibilities.
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
'03 Blazer wont start...tried everything I know junior7 Problem Diagnosis 8 02-21-2009 06:36 PM
2000 stratus wont start tried everything HELP!!!! evilshedd Stratus 1 02-29-2004 06:19 PM
