Old 02-07-2004, 09:18 AM
AlwaysMovin AlwaysMovin is offline
Question ??? Light weight parts lose torque ???
I read on another forum a couple days ago that light weight underdrive pulleys decrease torque output. Which does not sound right. Light engine parts, pulleys, flywheels, CVs, etc... Should allow you to redirect torque to the wheels rather than actually decrease the torque output of the engine right??? Somebody speak on this...
If you are ever in the southwest desert and you see a dust storm coming your way, when I see you I'll wave hello.
My Home Page: Under Heavy Construction
Old 02-07-2004, 10:45 AM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: ??? Light weight parts lose torque ???
I have never heard that. But with the underdrive pulleys you will see very, and I mean very little gain.
Old 02-09-2004, 09:00 PM
spooleffect's Avatar
spooleffect spooleffect is offline
Send a message via AIM to spooleffect
How? How is it gonna reduce your engines output? It ain't. Lightweight parts will not increase your tourque output though. Its will increase your horsepower(NOT CREATE IT!) because the engine can now apply torque at a faster rate due to less mass, this increase is likely to be very small though. A lightweight flywheel can have the greatest effect to an engine, a lightend flywheel can lose your car more than 100lbs in rotational force in first gear.
Old 02-09-2004, 10:43 PM
See thats what I thought. But this guy was totally adamant that a lightweight flywheel would cause his truck to lose torque. Oh well some people.
Old 02-10-2004, 01:10 AM
silky4u's Avatar
silky4u silky4u is offline
While a lightened flywheel will reduce the inertia of your flywheel and give your more engine response via quicker revving and rpm slowdown, at a certain level your engine uses this rotating mass to help counteract firing pulses, stop vibration harmonics, and tortional twist. Most 4 cylinders dont use a vibrational damper like v8's so this vibration may be quite noticeable. This vibration (along with being bothersome) can affect your synchros and tranny seals in a negative way, flywheels that have been lightened improperly, or too much, can be bent by the pressure plate on disengagement and cause unnecessary action upon the synchros and thrust loads on the engine thrust bearing and tranny seals. When using lightened flywheels (especially very light ones) it is advisable to balance the crank to assist. Its true that you will notice a difference in power but, without the proper precautions can affect you negatively. Without this rotating mass, say on a flywheel, a driver may confuse the new power output with a loss in torque
I hate ALL people!
Old 02-10-2004, 08:59 AM
Ok, that makes sense as well. Are these kind of problems going to show up in 4 cyl. truck though? Something like a KA24DE Nissan or a 22RE Toyota. Consequently Honda engines do use a harmonic balancer it claims to be attached to the crank pulley.
Old 02-10-2004, 09:02 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
When I installed an Unorthadox crank pulley on my DX I freed up 6hp at the wheels.. Throttle response picked up a bit, so I don't see how you could lose torque.
Old 02-10-2004, 04:35 PM
Good lightweight flyweels are balanced and keep the engine rotating smoothly. In 4 Bangers a Power Stroke doesn't happen often enough(180) to create a bad vibration. If your cars engine is not tuned well or another component of the enigne is unbalanced, then this all goes to hell though.
Old 02-10-2004, 11:49 PM
got v-tec?'s Avatar
got v-tec? got v-tec? is offline
Re: Re: ??? Light weight parts lose torque ???
my unorthodox crank shaft pullie freed up 1.4whp and 2.2tq on my b18c1
civ eg hb/b18c1
PT61 .68ar p-trim
Full-race pro street manifold
Neptune EMS
412whp@10psi 11.62@118
633whp@28psi 10.45@135
Old 02-11-2004, 10:47 AM
Ricochet's Avatar
Banned
Re: Re: Re: ??? Light weight parts lose torque ???
haha d16 > b18
Old 02-11-2004, 03:03 PM
I would definately agree. Throttle response is measurably quicker. And I think we can say that the guy who thought lightweight parts will cause his engine to lose torque was full of it.
Losing torque in 1st bag91 Camaro Discussions 3 01-13-2006 11:05 PM
Light Weight Smaller Overdrive Pulley Decreases HP?!? amdsoldier Off-Topic 33 01-26-2004 06:49 PM
light weight but cool ChukBzle 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 5 11-02-2003 01:14 PM
Light Weight Flywheels???? TypeSHLuder Engineering/ Technical 16 05-31-2003 01:26 PM
Light weight oils......pfttt B16a4me Asia/Pacific 11 06-27-2002 03:25 AM
