Old 02-07-2004, 05:08 AM
hallie hallie is offline
intake manifold gasket - Gasket Goo?
hi all
I am reconditioning a 1.5L Mazda 323 head. single o'head cam. Now ready to refit the inlet manifold with a new gasket. The workshop manual does not mention anything about using gasket goo (cement), but it does for other gaskets such as thermostat housing and water pump. So, do I need to use goo when refitting the inlet manifold?
Also, there was a metal spacer plate fitted between the head and manifold, about 1/4 inch thick, yet the manual makes no reference to it. Does it need to be fitted? If so, where? Does the gasket go on the head side of the plate or the manifold side, or do I need two gaskets? I purchased a full head gasket set and it only came with one gasket...
I have asked a few mechanic friends, but get different answers. Others don't know. Anyone assist?
Old 02-07-2004, 10:13 AM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
Re: intake manifold gasket - Gasket Goo?
Originally Posted by hallie
hi all
I will assume 'inlet manifold' is the same as intake manifold.
The spacer, if used, use again
to guard against leaks on a straight air intake (meaning no water or exhaust ports) just use some permatex part 2B or equivalent to 'glue it on', the gasket should go on the manifold side
if you have not done the head yet, and its a shim gasket (all metal and flat) then use some 'indian head' shellac or some permatex coper spray, and thats it. if it is composite (graphite, paper with steel side or fire rings) then use copper spray lightly.
Old 02-07-2004, 08:20 PM
Thx for the prompt response.
I have just returned from an auto spares shop an talked to the resident expert. He mentioned copper spray too. But leaned towards a non hardening black sealant goo to use, especially around the water passages.
I mentioned the spacer plate to him. He was not sure about it. the engineering campany that machined the head said not to use the spacer.
When removing the spacer it had two thin paper gaskets each side. The gasket I have bought is made of a grey cardboard material. The spacer is hard steel, fairly clean but some tiny pit marks around the water passages.
Am I on the right track if I use this gasket goo, and should it be used between the spacer and the head?
Thx again.
Old 02-08-2004, 11:25 AM
Thx again.
Id make sure the spacer is not factory or dealer add - typically they serve 2 purposes: 1) increase torque by effectively lengthening the runners 2) insulate the intake hence fuel system from engine heat soak
that spacer may very well have been put there by a mazda representative
as for head gasket, I have never seen any sealant applicable to head gaskets that stay pliable, and to tel lthe truth, you dont want excess pliability.
Old 02-10-2004, 01:49 AM
Thx for the info.
Have contacted cheif engineer at Mazda, he has never heard of spacer being fitted by factoy. He recommended contacting genuine Mazda spare parts dealer, i did and the rep had been with Mazda 25 years.
He said spacer not fitted by Mazda and felt it must be there for a reason so put it back with a gasket either side, no goo.
So I have done that.
Thankyou for your help. Time will tell.
99 Windstar 3.8L Replacing Intake Manifold Gaskets dariem Windstar 8 03-21-2015 05:22 PM
Replacing LIM Gasket TIPS mpit91 Grand AM 5 01-31-2012 02:53 PM
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 08:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 12:13 AM
2002 2.7L Intake manifolds ksparticuspa Intrepid 1 07-02-2010 02:25 AM
