Old 02-07-2004, 01:54 AM
captusa captusa is offline
98 suburban battery drain problem. Any ideas
My 98 suburban battery drains to the point it won't start after a couple of hours. It has a new alternator in Dec 03, and a new battery at the same time. Jumps easy and runs great afterwards, but dies again after it sits a couple of hours. I've checked all the light switches and everything I can think of. The alternator is charging fine. Any ideas would be greatly appreciated.
Old 02-08-2004, 09:38 AM
Jeremy-WI Jeremy-WI is offline
Re: 98 suburban battery drain problem. Any ideas
After you shut off your vehicle, unplug the oil pressure sender, its at the back of the engine to the drivers side of the distributor, I am fairly sure this has 12v to it all the time and can energize your fuel pump, just plug it back in before you start it again
Old 03-20-2004, 12:00 PM
pdalton pdalton is offline
On my 97, a similar battery draining problem turned out to be the underhood light staying on when the hood was closed. It's sort of hard to detectby watching as the hood is colsing, so try removing the bulb for a while.
- Paul
Old 03-20-2004, 02:23 PM
Cleveland Metal Cleveland Metal is offline
You can also try disconnecting the alternator for a while and see if that could be it. If diodes pop in them, they will drain the battery.
Old 03-22-2004, 04:28 PM
bigeasy bigeasy is offline
the factory security system had the same draining effect on my 96 model burb. I bypassed and disconnected. have not replaced it and don't miss it!
Old 04-08-2004, 11:13 AM
rstang rstang is offline
I have a 96 gmc suburban I had the same problem and it was the fan motor for the rear air.
Old 01-15-2008, 10:37 AM
cjbstuff cjbstuff is offline
After spending over $300 for the dealer to look at my 97' Suburban - I looked up on this website and sure enough the rear blower is what was causing my truck to drain the battery - really annoying spending money and having nothing to show for it... I left it unplugged - three separate connections needed to be pulled.
Old 01-15-2008, 03:32 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Wow... resurecting a 4 year old post... that's got to be a record
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
2001 gls battery drain jetta_help_needed Jetta/Vento/Bora 7 02-18-2011 12:37 AM
2006 Grand Prix Battery Drain wratchetjaw Grand Prix 9 12-20-2010 04:18 PM
2001 Olds Alero Battery Drain Issue Xenokira Alero 3 04-20-2009 10:04 PM
2001 Cavalier Battery Drain Problem - HELP amberdamber7 Cavalier Problem Diagnosis 25 03-25-2009 06:30 PM
99 Suburban Problem - any ideas? ThePierogiKid Suburban 2 02-16-2006 07:13 PM
