Old 02-06-2004, 10:42 PM
King Cobra 22 King Cobra 22 is offline
Will this car run 13's?
Will a 1994 mustang gt (auto) vert run 13's with the following mods 3:73 gears,shift kit,Torque Converter,Flowmaster exhaust,h pipe,headers,Cai,pulleys,posi,Timing at 14,and a cobra intake?
Around how much hp will this car be giving out at the engine and wheels?
Old 02-06-2004, 10:50 PM
90Stangjc 90Stangjc is offline
Well, wouldnt they run like high 15's or low 16's stock. Ewww...
I think maybe mid 14's to low 14's. Probably not 13's. A 215 hp automatic convertable just......hmmmm.....
1999 Camaro Z28 M6- Aftermarket mods- LS6 Intake, Chip
Home mods - Ram Air mod, !CAGS
FACTORY FREAK BIOTCH!
Old 02-06-2004, 10:51 PM
HotBoys09's Avatar
HotBoys09 HotBoys09 is offline
Send a message via AIM to HotBoys09
I would believe it would if you could hook up right. Put some slicks on before you race then deff.
1999 Plymouth Breeze
1995 Ford Probe GT - R.I.P.
1987 Dodge Daytona Shelby Z
WTB 98+ Formula/TA or Z28
Old 02-06-2004, 11:11 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Will this car run 13's?
Not even a chance you'll see 13's with those little mods! I say maybe mid to low 14's at best.
For hp with those mods, I saw you will have about 230-240 at the flywheel.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 02-06-2004, 11:24 PM
Around how much would the mods in that car cost new? used?
Old 02-07-2004, 07:12 AM
HotBoys09's Avatar
Re: Re: Will this car run 13's?
I don't know man I've seen mustangs get anywhere from 14.4-up with Just full exhaust, posi, CAI, and pulleys w/ slicks on, if you throw more on top of that you kep shedding every little .1. IMO.
And a pretty good place to find used parts like that would either be on here, a mustang forum, or EBAY.
P.S. I might be sounding stupid by saying this but, how can you have a CAI, AND, an intake off a cobra? I just dont understand...
Old 02-07-2004, 09:48 AM
HiFlow5 0's Avatar
Stanger
Re: Re: Re: Will this car run 13's?
Keep in mind, he has three black marks against him from the start.
1, auto
2, vert
3, heavy SN95 body style.
Stock that car is going to run probably mid 15's with a good driver.
The mods he listed are great starters, just not enough to push that car into the 13's. A properly selected stall converter, 3.73's and shift kit will definitely help in acceleration, and will help him break into the 14's for sure.
Then there's the potential hp mods. The biggest one will be the complete exhaust freeing up the most hp then the others listed. Pulleys will free up a few more pony's, but nothing noticeable. CAI, won't do a damn thing! And a Cobra intake, may add a few more horses, but it won't be too much with the rest of the induction still stock.
P.S. I might be sounding stupid by saying this but, how can you have a CAI, AND, an intake off a cobra? I just don't understand...
A Cobra intake manifold is pretty much just a swap from the original. It will flow a little better. A CAI (cold air intake) attaches to the manifold and to the air filter. It's supposed to pull a cooler air in from outside the engine bay though the fender well. It basically does the same thing as the stock air box inlet pipe, but just looks better then stock.
-2013 Ford Flex
-1999 Ford F150
Old 02-07-2004, 05:22 PM
mwarrior mwarrior is offline
Banned
While the SN-95 body style is 'heavier', the 94 style still wasnt as boxy as the '99-up style. With those mods and that motor (which I believe is the same motor as the '90-93 if i'm not wrong?), I'd say low 14s or if you're lucky high 13s with slicks and some good launches.
That being said, the flowmaster is good for 'rumble' but not as much power as magnaflow, and find out if the H-Pipe is catted or not, or if its factory even.
I'm running 14.1 on my '01 GT Convertible with auto, and my mods are a programmer, K&N filter, and minimum of 93 octane, regular street tires. But I was also running 14.48 stock. I'm pushing 225hp at the wheels if that helps you.
For power the best thing to do is take it out to a dyno and have it checked since it looks like you're buying this, and the dyno runs cost a max of $80 anyways.
Gagan
Old 02-09-2004, 05:41 PM
mycobra70la mycobra70la is offline
I'm thinking mid 14's. Like stated auto, vert "weight"
what will make this car run right? stokin393 ZX2 1 07-30-2006 11:10 PM
will my car run without the cyl. #1 position sensor. 2poor2tune '88 - '91 Civic | CRX | Wagon | Shuttlee 8 07-22-2006 02:10 AM
Would this car run 12s or high 11's? Ispankyourmom Engineering/ Technical 42 01-07-2004 10:06 AM
what will this civic run!!!!!!!!! crazyH '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 11-10-2003 10:30 PM
Will this car pass a smog test? changedagame108 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 02-07-2002 10:16 PM
