Old 02-06-2004, 10:12 PM
Attilathehun Attilathehun is offline
camshaft position sensor problem!!
Can anyone tell me where the camshaft position sensor is located on the 3.8l 1995 windstar?i know:mounted on timing cover, but i did not find!!I have a book:Haynes Repair Manual 1995 Thru 2003, and not included pictures abaut 95-3.8l! i buyed sensor from the AutoZone, "wells f 153" But i think the size different then i find on timing cover! I find a bigger one!need a help ! Thank's
Attila
Old 02-09-2004, 08:17 PM
busboy4 busboy4 is offline
Re: camshaft position sensor problem!!
Hi,
on my '96 3.8l the sensor is fairly easily visible just inboard of the water pump, aft of the alternator. It has a hold-down screw and washer that overlaps the housing.
In my factory shop manual, it indicates that changing it is a dicey proposition as the ignition timing is derived primarily from this sensor. Alignment is critical and the manual specifies a tool to do so, in addition to properly setting the #1 cylinder to TDC prior to removal. I don't know anything of your experience, but it doesn't look like a casual weekender job to me.
Let me know if I can provide any more info. Meanwhile you might call around and get a quote on installation.
Old 06-27-2004, 05:02 PM
Gloriahusk's Avatar
Gloriahusk Gloriahusk is offline
Send a message via AIM to Gloriahusk
Talking Re: camshaft position sensor problem!!
I just replaced my CMP today, it took 10 minutes, 5 of those was trying to find what the kids did with my tools...(haha).
Make sure that you have checked your Crank Shaft Position sensor as well. These two can go bad at the same time (CKP is $24.99 at Auto Zone)...
CMP sensor$32.00 at Auto Zone)
If you have to replace the entire drive Camshaft assembly you are better off going to the Ford dealer ship because must have the "special" Ford tool to replace it and of course it has to be done in spec.
If it's just the sensor you need to replace read below!
The CMP sensor is mounted on a drive unit. If you are replacing only the CMP sensor, remove the screws, detach the clip, and remove it from the drive assembly. Installation is the reverse. You do not have to remove the the drive assembly from the engine. You do not need any special tools.
94 3000gt jdm engine swap crank and camshaft position sensor problems. b18ceg 3000GT/Stealth 3 12-18-2009 05:47 PM
Vaiable valve timing control sensor or camshaft position sensor? 99 Mazda Roadster MX-5/ Miata 2 12-07-2009 09:36 AM
Pontiac GA Cam position sensor LOCATION ? cigars99 Grand AM 6 07-11-2009 10:30 AM
Problem locating the camshaft position sensor Talon69 Off-Topic 6 10-02-2005 10:03 PM
ugh!! camshaft positioning sensor or o2 sensor?!?! 1995EclipseGS Eclipse Problem Diagnosis 0 05-22-2005 10:24 AM
